All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: Sprinter on March 04, 2014, 10:12:53 PM
Title: Water to air fin coil & flat plate heat exchanger specification charts
Post by: Sprinter on March 04, 2014, 10:12:53 PM
Here are a couple links on BTU output, GPM flow, cfm flow , water temp, size and sizing info for calculating , planning or those who don't have labeled exchangers to get an idea on what you have.
http://www.firstco.com/getattachment/Products/Multi-Family-Residential-Products/Miscellaneous/HWC/hwc209.pdf (http://www.firstco.com/getattachment/Products/Multi-Family-Residential-Products/Miscellaneous/HWC/hwc209.pdf)
http://www.brazetek.com/finned-coil-water-air-heat-exchangers (http://www.brazetek.com/finned-coil-water-air-heat-exchangers)
Both have flat plate data sheets as well. If anyone finds more info please add
Title: Re: Water to air fin coil & flat plate heat exchanger specification charts
Post by: slimjim on March 07, 2014, 12:10:17 PM
Sprinter, how the heck do you find all this stuff and then how do you comprehend it!
Post by: Sprinter on March 07, 2014, 12:34:41 PM
Bump the spammers
Post by: Sprinter on June 05, 2014, 05:54:32 AM
Bump the spammers
