		All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: Hammersquash on September 02, 2014, 02:52:57 PM
				  I cracked open my plenum today to install my heating coil and much to my chagrin there is no room for it under the A coil.
  I have a Brunswick forced air Oil furnace and the A Coil only has about 2" above the peak of the 'A' so I can't raise it to install the water coil.
  Is it a viable solution to install the water exchanger on the cold air return side?
				That's what I had to do. I had the same issue.
				mine is to.does a good job ^-^
				Mine is in the return after the filter no problems.
				Mine is also on the return side.  Just make sure you put a filter before the coil and you won't have any issues.
				  Thank you very much to those who responded with the same issue I have.  I ended up making a tight install with a new filter bracket above coil.  I am very happy with the results and it was easier than lifting the house 5" to allow enough room to raise A coil.
A- Coil.  Not a great pic, but inlet side is restricted and there is no room to raise it as I have a 1880 farmhouse with low basement.
https://www.flickr.com/photos/123605823@N05/15011026098/ (https://www.flickr.com/photos/123605823@N05/15011026098/)
Pic of coil installed, pre soldering.
https://www.flickr.com/photos/123605823@N05/15174542986/ (https://www.flickr.com/photos/123605823@N05/15174542986/)
Another, before filter install.  (don't mind the dirty filters, they are gone now!)
https://www.flickr.com/photos/123605823@N05/15010783399/ (https://www.flickr.com/photos/123605823@N05/15010783399/)
Now installed.  Tight fit with new filters.
https://www.flickr.com/photos/123605823@N05/15010996027/ (https://www.flickr.com/photos/123605823@N05/15010996027/)
Buttoned up!
https://www.flickr.com/photos/123605823@N05/15010782569/ (https://www.flickr.com/photos/123605823@N05/15010782569/)
				Looks good!!
