All-Purpose OWF Discussions => Plumbing => Topic started by: Bud650 on September 11, 2014, 08:29:27 AM
I just bought a used CB 1400 3 years old and am looking to tie into my oil boiler I was told to t off my pressure re leaf valve for the inlet and t off the boiler drain for the outlet . I see that both of these are 3/4 in can anyone tell me if that will be enough flow in the oil boiler ?
It can be done but is not close to the right way to do it, are you going to use a plate exchanger?
I was going to try it this year with out the heat exchanger .
OK, I don't install that way, perhaps one of the Central boiler guys can help you then?
You realize that the indoor boiler is pressurized and the outdoor boiler is not? You would be turning your indoor boiler into a non pressurized system. I don't think this is going to work well for you at all. Save your self the headaches and spend the little bit of money on the plate exchanger.
Ok I will be purchasing a plate exchanger and installing it . Will the 3/4 in inlet in and outlet in the oil boiler be big enough ?
That depends on your heat load, if you need more than about 100,000 Btu then no way, it seems somebody misled you a bit, I will be at the Unity / common ground fair next weekend if you would like to talk, a diagram of what you have now would help.
I do plan on being at the common ground fair an meeting you. my oil boiler is 117000 btu.
OK, look me up, I will have our chip boiler as well as the optimizer 250 running on the back row.
