Outdoor Furnaces - Manufacturers with NON EPA-Certified Models Only => RidgeWood Stoves, defunct, support only => Topic started by: Roscoe on October 01, 2014, 12:56:09 PM
Title: 6000 / 7500 pump hook up
Post by: Roscoe on October 01, 2014, 12:56:09 PM
Just took delivery of my 7500. After checking it out, I found there isn't too much room for pump hook up without the pump(s) hanging out the bottom of the stove frame. I'm trying to stay away from a bunch of 90's in the pumping. Anyone care to post pics of their pump hook up? Thanks
Title: Re: 6000 / 7500 pump hook up
Post by: jamesbodeis on October 02, 2014, 08:11:51 AM
mine hangs out the bottom on my 7500. I plan on making some kind of skirt to put around it to keep everything out of the elements. Dont have a pic at the moment.
Post by: automan77 on October 02, 2014, 08:26:25 AM
My pump is protected by that back panel  on the 6000.
Post by: 6pacmac on October 02, 2014, 03:17:58 PM
There is a pic of the pump area on the Ridgewood site in the gallery section :pic:
Post by: solarman on October 02, 2014, 05:01:01 PM
If the water will gravity feed from the stove to the house, then put the pump inside the house. If it will not then try and install the pump straight out from the stove then 90 down, not sure if there is room to do this or not, it would be tight.
I completely closed the bottom of my 6000 in with 26 gauge galvanized sheet medal, through some extra fiberglass insulation in there also I had laying around.
Post by: solarman on October 02, 2014, 05:03:36 PM
I would not worry about 90's in the piping system, water is pumping through it. If it was drains then I would worry.
Post by: Roscoe on October 05, 2014, 08:18:56 PM
No room to position the pumps straight out of the stove. I reduced to 1" copper and used copper flex pipe to get things in line. The same stuff used for the top of hot water heaters. I'm building an insulated box around the unprotected lines. Also going to insulate around the connection area. Kinda disappointed on how exposed the bottom of the stove is.
Post by: solarman on October 06, 2014, 05:43:09 PM
Hi I ran my piping in a 8" pipe to keep them out of the wind.
Also screwed up sheet medal on the underside or the stove including the pump area.
It is a easy upgrade to do. I will send pics.
Kyle
Post by: solarman on October 06, 2014, 05:46:39 PM
8" pipe for running piping through.
Post by: Chas on October 06, 2014, 06:24:18 PM
I was able to put my pumps in the basement and shop like Solarman suggested. Also take a look at the post in the Ridgewood section about "Ridgewood skirt and light." Golffanman put a skirt on his and I copied his idea. Seals it up nicely.
Post by: mlappin on October 06, 2014, 09:15:57 PM
Sounds like in all other aspects everybody that has a Ridgewood is pretty happy with them, too bad they seemed to have dropped the ball on this one minor issue.
Post by: chillyhiker on October 31, 2014, 05:49:04 PM
I was thinking about putting insulation like you but was worried about a mouse making a nest... :o
