All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: AirForcePOL on October 02, 2014, 09:17:32 AM
Title: Sharkbite guages
Post by: AirForcePOL on October 02, 2014, 09:17:32 AM
Has anyone used these guages before?  It seems pretty cheap for a Sharkbite fitting.
http://www.altheatsupply.com/shop-by-needs/outdoor-wood-furnace-parts/thermostats-gauges/sharkbite-pressure-gauge.html (http://www.altheatsupply.com/shop-by-needs/outdoor-wood-furnace-parts/thermostats-gauges/sharkbite-pressure-gauge.html)
Title: Re: Sharkbite guages
Post by: Steinacher Sales on October 02, 2014, 10:07:15 AM
Airforce,
These are pressure gauges that you are siting, an open system will not show much pressure I would not think. The temp. gauges are a lot higher. The 1" is around $40.00!
Greg Steinacher
618-401-0726
www.midwestoutdoorfurnace.com (http://www.midwestoutdoorfurnace.com)
Post by: automan77 on October 02, 2014, 10:56:26 AM
I have a 1" temp gauge  I think it was 35 or 40.  Shark bite
Post by: AirForcePOL on October 02, 2014, 12:08:55 PM
ooops you're right thanks.  What is the cheapest way of installing a temp guage other than a strap on?  I have a strap on but i just feel like you dont get the most accurate readings with it.
Post by: mlappin on October 02, 2014, 01:45:14 PM
Use a little of that paste like you use on the cooling fans for the CPU in a desktop.
Post by: AirForcePOL on October 02, 2014, 01:48:12 PM
I used some of that on the one i had.  I think I'm just going to buy one or two of the meat probes and put that paste on them and tape them up real good.  Wireless monitoring would be preferred anyway.
Post by: automan77 on October 02, 2014, 03:05:09 PM
Supply house.com has the temp gauges
Post by: yoderheating on October 02, 2014, 09:33:08 PM
 I've used those on infloor heat jobs and they worked really well. It allows me to adjust my mixing valve to exact temps as needed.
Post by: WoodMOJoe on October 06, 2014, 07:06:06 AM
Great idea, gonna give that a try when I install my wireless bbq probes in a month or so.  Think I already have a tube of it.   :thumbup:
Post by: AirForcePOL on October 06, 2014, 07:51:01 AM
That's my plan too.  I just bought two of the meat thermometers on Amazon for $34 each they are the Maverick ET-73 model.
Post by: GCTerpfan on October 06, 2014, 09:37:52 AM
Are the wireless BBQ thermometers battery operated?  Do you plan on letting them on 24/7?  How long do you think the batteries would last if you do?
It seems like a "pretty slick" and cheap alternative if you don't end up replacing batteries every week.
Post by: AirForcePOL on October 06, 2014, 09:40:07 AM
Yea they are battery operated.  Someone on this site said the batteries will last a while.  Like a year or two.  We will see.
Post by: GCTerpfan on October 06, 2014, 10:00:13 AM
I might have to give this a try.  The one you listed has two probes, so you could monitor the supply and return temps at the same time.
Post by: AirForcePOL on October 06, 2014, 10:12:20 AM
yep.  It's perfect for monitoring both temps.  I'm not sure what the accuracy will be when measuring the temp through pex but the difference should be the same if the temp is measured off of the same type of surface on both probes.  It should do a good job at measuring what the difference is in the supply and return lines.  Here is a link to the ones I bought.  http://www.amazon.com/Maverick-Remote-Smoker-Thermometer-ET-73/dp/B00EQFFOLA/ref=sr_1_5?ie=UTF8&qid=1412611358&sr=8-5&keywords=maverick+et-73 (http://www.amazon.com/Maverick-Remote-Smoker-Thermometer-ET-73/dp/B00EQFFOLA/ref=sr_1_5?ie=UTF8&qid=1412611358&sr=8-5&keywords=maverick+et-73)
Post by: smitty33 on October 06, 2014, 04:47:33 PM
I have the maverick wireless set up on mine. Works great.  Make sure the probes are on copper or some kind of metal. It will not read correct on pex. Batteries on mine last about 6 months. Also has Hi and low alert.
Post by: mlappin on October 06, 2014, 09:23:04 PM
I should have added, use the thermal paste and if you can get it, use foil tape as well.
Post by: mlappin on October 06, 2014, 09:33:03 PM
Now to stir the pot a bit, anybody find something similar to the maverick wireless model sans the wireless?
Cheapest way I've found so far would be using something like this, but I really don't need the wireless part. I was planning on using two of these units to monitor the flat plate heat exchanger temps between the shop boiler and the OWB. I wouldn't think two wireless units would interfere with one another?
Post by: GCTerpfan on October 07, 2014, 06:32:32 AM
My guess is that two of the same brand wireless units probably would interfere with each other. A not so funny/funny story about wireless interference, a friend had a remote starter on his manual shift Bronco, he would leave the Bronco in neutral during the winter so that he could use it.  One day,while in my buddy's driveway, his brother activated an aftermarket car alarm made by the same company .  The alarm signal activated the remote starter on my buddy's  Bronco and because it was summer the Bronco was in gear, it jumped forward, straight off a 6 foot high retaining wall and landed in a pontoon boat my buddy had just finished restoring.  I thought it was funny, my buddy didn't.
If you don't need the wireless option for the second location you can pick up a wired digital meat probe for $5 at walmart, I have one I use for my smoker.
