All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: shoebox on November 02, 2014, 08:26:19 AM
There are 3 settings on my pump, just don't know which is ideal. I run 1" lines, 70' run to a water to air exchanger
I'm thinking most will say the highest setting. Has something to do with circulating the hottest water possible back in the OWF
:post:
Greg Steinacher
618-401-0726
www.midwestoutdoorfurnace.com (http://www.midwestoutdoorfurnace.com)
...as long as you don't hear a gravelly sound in your pipes you should be good. Excessive noise in a hydronic system is never a good thing; because its either air in the system (not good) or you are overpumping system (causing turbulance and potentialy eroding metal fittings
