All-Purpose OWF Discussions => Plumbing => Topic started by: coolidge on December 22, 2014, 06:05:41 PM
Had the day off today, looking over the garage system. I have radiant in the floor and a water-to-air exchanger hanging on the wall for backup I guess. Thinking if I turn down the radiant to say 80 and have the exchanger come on when call for heat I might use a little less wood?
Good thing I need to go to work tomorrow.
What is your radiant at now?
you keep your garage 80 degrees?
Radiant is running at 120 now. I like too keep it 68 to 70 my work materials are much better to use when warm. I had a plan to rock the ceiling this past summer, didn't happen. Don't want to rush things.
Garage is well insulated.
The only thing you gain by dropping the water temperature; is a more consistant floor temperature, but you will be increasing your calls for heat because the lower water temps will not transfer as much energy!
I would leave water temp at 120F, I do not think you will see enough energy saving to really matter
I agree with Littlejohn probably not enough to notice.
