All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: bucky1399 on January 12, 2015, 07:00:39 PM
Looking for some advice on heating a 2.5 car garage. Has anyone installed one of these units from outdoorfurnacesupply?
http://www.outdoorfurnacesupply.com/water-to-air-heat-exchangers/uh50.html (http://www.outdoorfurnacesupply.com/water-to-air-heat-exchangers/uh50.html)
They have a 3 year warranty, compared to the Dragon Breath heater, 1 year. Dragon Breath is over twice as much.
Also found the Modine H2ot Dawg...for almost a grand...ouch. Would consider fabricating my own unit, but with the price of the outdoorfurnacesupply unit I would save myself the hassle. Any thoughts/suggestions?
Will 50,000 BTU heat your 2.5 car garage adequately?
I think so. Most research I've found recommends 45k for 2.5 car garage. If I can get the garage to 50-55 degrees for working on vehicles I would be happy with that.
I don't have that particular unit heater, but I bought the bulk of my supplies for my original install from outdoorfurnacesupply. I have had no problems with anything I bought from them and he was very helpful answering questions and making suggestions before and during my build. If my history is any indicator, I think you will be satisfied.
I bought a 100,000 but unit from badgerinsulatedpipe.com for $291 and it works great on my 30x40 garage with 11' ceilings. I had free shipping as I also got other supplies to hit $500. The heater you are looking at is probably the same brand as mine just smaller. So if it is rated as the size you need then it should work fine. I have mine hard wired to a thermostat, but I know they sell a plug in thermostat that they said most customers use with it. I keep my garage right around 60.
I have two of the 89k btu, only one being used right now, works good.
Look on craigslist for furnaces. I found a Lennox Pulse made in 1995. The heat exchanger was cracked but the fan was good. I made a "hood" to put on the air outlet and plumbed in a water to air heat exchanger, hooked up a thermostat and I'm heating a 3 1/2 car garage with it. I have $186 and my time in it. Had a "Hawaiian" party in it last weekend. Outside was -3, inside was 91.
Way to go Bud Man, I would have been there but my invitation must have gotten lost in the mail
Bucky1999,
I have this exact heater in my garage (36 x 26 with 12.6" ceiling) and it does the job. However - it is extremely loud with the fan set up it uses. You might be able to quiet it down by building something around it. I also have big ole cast iron rads that i primarily use for heat- I turn the unit on you are looking at when temps drop below -10.
I build my own heaters , its pretty simple and they work well , I use them to heat 2 large greenhouses so they would do a garage or shop easily I buy one 22x22 heat exchanger---176.00 , 1 Lasko 2265QM 20-Inch Max Performance fan =75.00 1 thermost --37.00 , build a wood frame 12-14 wide and mount the heat exchanger in it ,mount the fan on backside and plug the fan into the thermostat and locate the thermostat on other side of room ,
http://www.ebay.com/itm/22x22-Water-to-Air-Heat-Exchanger-Hot-Water-Coil-Outdoor-Wood-Furnace-/191070469563?pt=LH_DefaultDomain_0&hash=item2c7caffdbb (http://www.ebay.com/itm/22x22-Water-to-Air-Heat-Exchanger-Hot-Water-Coil-Outdoor-Wood-Furnace-/191070469563?pt=LH_DefaultDomain_0&hash=item2c7caffdbb)
http://www.amazon.com/Lasko-2265QM-20-Inch-Performance-Velocity/dp/B0073CQ9XA (http://www.amazon.com/Lasko-2265QM-20-Inch-Performance-Velocity/dp/B0073CQ9XA)
http://www.amazon.com/gp/product/B000E7NYY8/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1 (http://www.amazon.com/gp/product/B000E7NYY8/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1)
Ive been running these 2 years now, no issues , you can adjust the size of your eat exchanger accordingly but that one there will do it no problem
I like that!!!!!!
thanks for the links
Bucky1999,
heatthefarm-Do you think this unit is enough to heat the garage on it's own? My garage is 650 sq ft, 9' ceiling? Any benefit in getting a unit with a multispeed fan?
I wish mine had a multi speed fan.
LIke netwerx, I built my own. Hx size 18 x 18. A also put an air filter on it since my 24 x 30 garage doubles as a metal/wood work shop.
Slimjim, that's why the mailman was here. He kept your invitation, can't trust anyone.
You let me know when you're coming and I will have another "Hawaiian" party. Or whatever kind of party you want to have.
Especially not federal government employees.
