Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Central Boiler => Topic started by: sabercat on October 18, 2015, 05:38:26 PM
I have a 3 year old 5036. I have to replace the chimney tee, and when I got it tore apart I noticed the pipe was in rough shape also, the SS liner was warped, like the tee was. I got the tee at the local dealer, and I didn't get the price from them on the pipe. It is probably expensive, but anyone have a place to get the Hi-Heat pipe? Oh ya the dealer said I must have had some hi temp in there. What size is this pipe considered 8" ? Thanks
You should be able to get the pice you need from your
Dealer you will also need a rope gasket that goes on end in the boiler
We had to replace one at the shop and it was covered under the central boiler warranty
Im supprised the tee han pipes had to be replaced. Do you clean it?I havent touched mine. This is year 6.
Ya me too, the metal was peeled up around where the pipe went up, and the first joint of pipe was frayed also. I puller the clean out lid off probably start and half way thru the winter and checked for ash etc. It was never really creasoted up, just usually some fine ash.
Sorry for waiting so long. I think thats just the way its assembled.
