All-Purpose OWF Discussions => Plumbing => Topic started by: JDfarmer on October 19, 2015, 01:55:24 PM
Title: Vertical Y Type Strainer filter
Post by: JDfarmer on October 19, 2015, 01:55:24 PM
Is there a problem installing a Y Type Strainer filter vertically at the boiler, where the line goes into the ground under the boiler's service door before the water pump? I have little room inside, and it would be much easier at the boiler. All the mess is outside.
thanks.
Title: Re: Vertical Y Type Strainer filter
Post by: RSI on October 19, 2015, 09:57:42 PM
Do you mean you are putting it between the boiler and pump? If so, that is not a good idea. If after the pump, which way it your pump mounted? Does it point up or down. If down, I wouldn't put it there either since it would be below the bottom of the boiler.
About half way down on this page it shows the mounting positions that can be used. http://media.wattswater.com/1915978.pdf
Post by: JDfarmer on October 20, 2015, 09:43:39 PM
RSI;
thanks for the reply, and the info.
I am trying to find a good place for it.
I have a NCB250 coal which I love, other then my awesome dealer no longer around and I can't find anyone who could support my boiler in Ohio. Anyway.
Last year (my boiler's 3rd year), I took out the drain plug that is in the bottom of the boiler, and there was no water draining because there was some sediment. I rinsed out the boiler, but I thought it might be a good idea to put in a filter because I have both DHW side arm, and water/air plenum heat exchanger for central heat for the boiler.
I prefer to keep it outside in case it leaks, but I understand that it probably be best in the basement before the incoming water goes to the DHW sidearm and then to the water/air exchanger.
Q1; where do you prefer the filter at? in the house before the DHW, and water air exchanger?
Q2; I'd like to get a high quality easy to clean filter, even if it's more money. Which one, or is there one you recommend?
I have pex pipes, and I do have room in the basement to instal one. I'd like to get a good one, that is easy to clean.
I just changed the door seals, so we are ready to go.
Thanks a lot.
Post by: RSI on October 21, 2015, 10:33:18 PM
If you want an actual filter instead of a strainer, I don't think there are many options out there. Rusco makes one. The version that is rated for enough temp is the black spin down. There is another brand that is similar but I can't remember the name right now. I think both only come in 3/4" or 1-1/4".
I would go with the 1-1/4" or else clean it fairly often.
It probably doesn't make a huge difference where you put it in the system. I would put a bypass around it and valves so you can clean it without having to shut anything down.
Post by: schoppy on October 21, 2015, 11:44:16 PM
Hey RSI, do you always put a strainer in your installs? My supplies are mid way up on the back of the boiler and it has a 1" drain at the bottom. Just wondering if you flush the drain periodically if that would be sufficient?
Post by: JDfarmer on October 22, 2015, 08:34:42 AM
Thanks guys.
I got a 1" y-strainer on ebay that was already assembled with the shark bite push connectors.
like this one http://www.freeheat4u.com/search.asp?keyword=y+strainer&search=
thanks
Post by: RSI on October 27, 2015, 12:41:05 PM
I used to but quit because no one ever cleaned them. If you put them in you should open and clean them at least once or twice a year even if you never find anything in them. Otherwise if it does plug up you might not be able to get it open.
If you have stuff floating in the water when you pull a sample, then I would consider adding a filter. If it is perfectly clean then it probably is all settled out and the filter won't catch much anyway.
Post by: schoppy on November 05, 2015, 12:07:54 AM
Sounds good and makes sense. Thanks.
