All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: hofmus on November 01, 2015, 10:28:45 AM
Title: cleaning firebox
Post by: hofmus on November 01, 2015, 10:28:45 AM
Almost time to fire up. Is there a way to get stubborn creosote off sides of firebox inside? I tried scrapping , but still hard as a rock? Any suggestions? Heatmore 200cs Thanks
Title: Re: cleaning firebox
Post by: fireboss on November 01, 2015, 12:12:36 PM
Burn lots of cardboard that will get it off!
Post by: U.P. Doug on November 01, 2015, 03:46:03 PM
I burned cardboard all day in the spring and it worked great. Turned the heat up in the garage to keep the fire going strong.
Post by: hofmus on November 01, 2015, 07:15:42 PM
Thanks for the info, Ill try it !
Post by: jerkash on November 02, 2015, 04:38:26 AM
Grinder or drill with a wire brush on it works after you burn it off with cardboard
Post by: pullerbob on November 02, 2015, 07:01:15 AM
You can also through some aluminum cans but you need it to be hot enough that it will melt the cans.
