All-Purpose OWF Discussions => Plumbing => Topic started by: heat550 on November 10, 2015, 12:55:08 AM
Title: pex valves / pex-al-pex plastic ring .
Post by: heat550 on November 10, 2015, 12:55:08 AM
I was looking I need about 10 x 1 inch pex valves and I seen ever-flow makes pex 1 inch with drain . I have all watts ball valves here now on stove . Is ever -flow a good ball valve also ? these will be used inside house with pex 1inch barrier. I never heard of them .
Pex-al-pex fittings ...I have 1 inch compression fitting they have a plastic ring in bottom to but up against the end of the pex -al-pex
when its pushed all the way in .  My old ones these rings are all cracked and deteriorated. on all 6 I have . do I need the plastic rings in there ? if there not in there I can just push pex -al-pex in farther . does the aluminum core in pex interact with the brass ?  or whats really the reason there in there ?  any info be great. deep in to plumbing .  :bag:
Heat550
