All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: beeman on January 17, 2011, 03:57:47 PM
i could use some advice from the many talenet on this site how do you make a door that is adjustable and a door lach
i could use some advice from the many talenet on this site how do you make a door that is adjustable and a door latch
I kept mine simple, i never allowed for adjustment I made my hinge out of pipe and a 3/4 inch rod that fit snugly inside and made the hinge like a piano hinge all the way the full length of the door. i am in year 11 and there is no wear that is showing yet
others likely have more elaborate set ups but i like simplicity
do you have a close up picture of your hinges and door latch thanks for help
Here is the linkto I believe page 5 on my build thread of how my hinges are made.
http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=642.60 (http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=642.60)
Mine are slotted to allow adjustment in and out for the shrinkage of the rope seal of the door.Plus to allow for a perfect fit of my door to the door frame opening.My latch is slotted so I can adjust it in and out to allow more or less pressure to be applied to the door.I also used studs to mount the hinge onto to allow the use of shims to align my door sideways.Worked out very nicely.good luck :thumbup:
