All-Purpose OWF Discussions => Plumbing => Topic started by: Sloppy_Snood on November 29, 2015, 05:33:55 PM
Title: 90 Degree Turn Copper Fitting Options
Post by: Sloppy_Snood on November 29, 2015, 05:33:55 PM
While most know that plumbing with short radius copper elbows can cause significant pressure drops and frictional losses in plumbing designs, I did not know what is more advantageous (in terms of flow, frictional loss, pressure drops) from what I see as the remaining options to turn 90 degrees: two 45s OR a long radius copper 90.
Which is "better?"  Two 45s or a long radius copper 90?
All I could find in the Engineering Toolbox was basically equivalent length figures for individual fitting types.  Is this also meaning better flow with less equivalent pipe lengths per fitting?  :-\
LINK:  http://www.engineeringtoolbox.com/resistance-equivalent-length-d_192.html
Title: Re: 90 Degree Turn Copper Fitting Options
Post by: mlappin on November 29, 2015, 06:36:49 PM
Long radius ninety means one less joint to solder.
I usually like to say away from street fittings, more restriction especially in steel or cast fittings.
Post by: Sloppy_Snood on November 29, 2015, 07:40:44 PM
Point taken on the reduction of soldered joints with the long radius copper 90s.  :thumbup:
That said, from a purely "better flow" perspective, slightly less "disruption" in the long radius copper elbow?  (Engineering Toolbox shows only a very slight difference)
More thoughts out there plumbing pros?
Post by: willieG on November 29, 2015, 08:20:21 PM
copper can be tight and neat and it gives off more heat than the pex. if you don't mind leaking heat where your pipes run
when my 1 inch pex enters the home I go straight into a 1 inch copper header and then down to 3/4 copper for my hot water tank and furnace exchanger  and then to 1/2 inch pex for floor heat (one loop) and 1/2 inch pex to a small exchanger in my fireplace
what leaks off the copper keeps the furnace room warm and dry
Post by: slimjim on November 30, 2015, 02:37:12 AM
45's are typically much cheaper but
have more resistance
look like crap
more labor installing
more chance of a leak
Long radius 90's win every time!
