All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: coolidge on January 02, 2016, 03:50:30 PM
Title: YTD usage 15/16
Post by: coolidge on January 02, 2016, 03:50:30 PM
4.5 cords since middle of Sept
Title: Re: YTD usage 15/16
Post by: willieG on January 02, 2016, 04:32:53 PM
same amount in the old silver bullet ( I dream of half the wood usage they say a gasser would bring me but I cant see me spending that amount of money)
250 feet of underground pipe (even though it is logstor) I know is costing me some large btu's as well
the underground pipe cost 3 times what the stove cost me..lol
scrimp everywhere you can BUT the underground lines
Post by: yotehunter66 on January 02, 2016, 04:45:54 PM
Probably about a chord since November 1st. Going through her now though with highs of 30.
Post by: mlappin on January 02, 2016, 05:27:50 PM
Expect to move up to about half a cord a week with the cooler weather.
Post by: hondaracer2oo4 on January 02, 2016, 06:19:10 PM
I started October 13th, just about cleared 3 cords.
Post by: Uponthehill on January 02, 2016, 09:24:45 PM
Since November 13 (Friday the 13th) I have burnt 3 rick or 1 1/2 chord of seasoned white oak.  Mostly 4 to 10 inch rounds.  House stays @ 75 (wife's request) and shop @ ~ 50.  Around 70 when I'm working.  Stay warm...
Post by: Cabo on January 03, 2016, 04:19:03 AM
Just a little over 2 1/3 cord since Oct. 17.
Post by: Roger2561 on January 03, 2016, 04:29:03 AM
Since mid October, approximately 1 1/2 cord of mixed hardwood.  Roger
Post by: fireman69lfd on January 03, 2016, 06:55:03 AM
About 1 3/4 cords since mid October. If it keeps up the way it's going now, I have next year's cut already!
Post by: kybaseball on January 03, 2016, 07:04:35 AM
We have had is easy so far and only used 1 1/2 cord of wood. Been trying different things with the stove like how much wood, which way to stack inside the stove and temps. Found that if i try to keep the wood to say a 8 to 10 hour burn time the stove works much better and using less wood with very little ashes and i mean very little.
Post by: hondaracer2oo4 on January 03, 2016, 08:01:50 AM
Roger, I am jealous of your numbers! We live not far away from each other and you have used half of what I have used! Your heat load must be much lower than mine or something. I can't even imagine how little wood I would have to throw in to only be at 1 1/2 cords over 2 and a half months into the burning season. Right now depending on the projected temps I am throwing in typically 5-6 splits that are 24 inches long and about 6-8 inches by 4-5 inches in diameter. In order to cut that in half I would have to throw in 2.5  splits every 12 hours. Doesn't seem like I could ever do that!
Post by: Roger2561 on January 03, 2016, 09:13:11 AM
Honaracer2004 - Last year I burned a tick over 8 cord for the entire heating season.  I'm heating approximately 4500sqft of an 1840's farmhouse plus DHW.  The house is 40ft X 40ft with a full basement.  The only heat that the basement gets in the winter is from the non-insulated hot-water pipes from the OWB.  I guess when the pipes are consistently around 190/195 degrees something is going to get warm.  I keep the living area of the house at 70/72 degrees 24/7 except my bedroom, that's at 65 degrees, if it's any warmer than that is too uncomfortable to sleep.  Over the years I've done a lot of improvements to the house; the kitchen (a separate room) was completely stripped to the bones and rebuilt.  It used to be drafty.  It's amazing what insulation and caulking will do to keep the drafts away.  My living room and dining room; again completely stripped to the bones and redone.  Its now an open concept, one large room instead of the two.  It's nearly 750sqft of living space.
Before my brother and I turned the second floor of the house into an apartment for him, it was never heated and poorly to non-existent in insulation.  When we started that project the entire second floor was completely stripped back to the bones and heavily insulated.  Now I have absolutely no heat loss through the second floor.  Every time I remodeled a room, I made sure to spray-foam or caulk all areas where there was a potential for drafts, AND then before rebuilding everything was heavily insulated.  It's made a world of difference in comfort while trying to read, listen to music or watch football.  Roger
Post by: hondaracer2oo4 on January 03, 2016, 09:34:18 AM
Well I am heating a 220 year old two story colonial. Foot print is 32x42 I believe. Basement is unheated 1/4 walking height / 3/4 crawl space. Attic is unused but high roof deck. I have brought all of the walls down to bare, foamed and chaukled each exterior sheathing board and batt insulated R15 with 1/2" of R3.3 rigid foam board over the studs and then sheet rock over that. Every room is done except one bedroom upstairs that is unused and unheated. I removed all of the attic insulation and airsealed with foam and chaulk every penetration through the ceiling into the attic. Then I laid down 8 inches of blown cellulose to fill the joist bays up to the top. Then I laid down R30 batts over the top of that which covers about 1/2-2/3s of the attic( I know I need to lay down the rest with R30 batts but I have storage that I have no where else to put at the moment). My sill plate I have gone around and sealed up with spray foam in any of the gaps but I don't have the sill insulated at all(it is an 8x8 sill). I heat with forced hot air(sometimes wish it was baseboard for comfort but I also don't like the wall space that baseboard takes up). I just can't get over that you can get 12 hours with only 2.5 splits. That is mind blowing to me.
Post by: Drivebymashing on January 03, 2016, 10:05:52 AM
October 18 to today ive used 1.5 cords. 1300 square foot modular and a 220 gallon hottub. Normally i use a cord a month. Its been pretty warm here in north carolina.
Post by: mlappin on January 03, 2016, 10:40:17 AM
I have about 235’ in the ground but in two runs, not sure how you can do any better other than sliding whatever you use inside some 6” PVC to add yet more thermal break.
Post by: tinfoilhat2020 on January 03, 2016, 02:30:19 PM
1 cord of pine/poplar, 2 cords of mixed hardwood since October 1st. Heating 4,000sqft + DHW. 1,000sqft (with 10ft ceilings) Dog facility is kept at 75-80°F. House is kept at 72°F and garage is kept at 65°F. Very pleased with the performance so far. 8-10 splits morning and night typically.
Post by: willieG on January 03, 2016, 03:45:46 PM
not saying I could do any better but the length does add up the losses. if you use  a 1 degree loss per 100 feet at 5 gpm and 32 degree soil temp, as they quote in their brochure... that's about 2.5 cords of wood for my average run time of 180 days. if I could (wife wont have it) move my stove to 100 feet I think that would only be about 1 cord extra
Post by: mlappin on January 03, 2016, 04:10:00 PM
Okay, I can see that.
My one run is pretty deep under the main drives and are slid thru 6” PVC just for sh*ts and giggles, then have sand around all of it, but being under the drives the frost gets drove deeper.
The run thru the yard is roughly 36” deep but in my experience with a good layer of sod, some landscaping and the fact it doesn’t even get walked on in the winter frost usually doesn’t go as deep in those situations.
Post by: coolidge on January 03, 2016, 04:51:47 PM
Wood usage should pick up a little with a couple nights below zero coming, then another warmup
Post by: willieG on January 03, 2016, 04:59:39 PM
240 feet of my 250 is under gravel driveway that is mostly kept snow free all winter, in recent years I have started pushing snow over the pipes  where I can, now I can keep about 1/3 of the underground length covered but with the varying winters we have been having I cant really say if I am saving  any wood or not.
Post by: intensedrive on January 03, 2016, 08:41:16 PM
Started heating October 15.  Burned roughly near 5.5 full cords :(  House kept at 70.
Post by: hondaracer2oo4 on January 04, 2016, 06:35:41 AM
I would be near that 5.5 with my old hardy h4. That is just the nature of the beast with the conventionals.
Post by: tinfoilhat2020 on January 04, 2016, 08:49:41 AM
my convention hasnt been that bad to be honest...it is also a bit over-sized....but so far so good!
Also....a guy down the road has a 22yr old HARDY....the thing is still kicking like the day he bought it....just helped the guy cut wood this past weekend...he said in 22yrs he has had to replace the door gasket a few times and the blower motor one time
Post by: AirForcePOL on January 04, 2016, 09:20:47 AM
Gone through 2.25 full cords in 1.5 months.  Heating 2200 sqft house and 1620 sqft shop.  House is 72 deg all the time and I keep the shop anywhere from 60-70.  I am using the same amount of wood to heat both my shop and my house than I did just heating the house last year with my 5000e.  I just added about 12 inches of blown insulation to the shop on Saturday so I am hoping that should make a pretty good difference in my consumption.
Post by: Ched Bull on January 04, 2016, 09:58:03 AM
3 cord since October 10th getting a lot of 24 hr burn times. :thumbup:
Post by: mlappin on January 04, 2016, 04:53:12 PM
Thats what I found when going to the G400, heated a lot more space on half the wood but it replaced a home built CB knockoff. Before all my old boiler did was to keep the 450 gallons of water in the shop hot, wanted to actually heat the shop then start the waste oil boiler as ole smokey could eat the wood about as fast as you threw it in when trying to do both.
