All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: atvalaska on January 16, 2016, 08:40:49 PM
Hey ....when u guys get smoke like a train in a old john Wayne movie pouring out ...what did u do …..or what is it caused by ...u share some info then I'll tell ya what is know...
The only time I've seen black smoke is when burning pine especially if it is not well cured. I suppose you could get it if you were burning garbage or old tires.
Usually that is caused by a hot fire and burning off the creosote build up....I'll pack mine with cardboard every so often and it will pour smoke like a choo choo train....just cleansing the stove is the way I see it :)
Coal can make a lot of black smoke. I am slowly figuring out how to burn it without all the smoke.
I have seen it with real dry wood from getting a fire burning super hot when loading and then closing the door smothers the fire and it can't get enough air to burn at the rate it was with the door open.
Yep, burning the creosote off makes a lot of black smoke
Well u guys were no help ...lol...I was thinking the stove is not getting enough air to real get going , I run her atn180 wit a 7.5 diff ....I'm afraid to open the door when the black is rolling as I don't need a hair cut !! ...my creasot is mirror like ...do that ain't it ....help !!!!
Your assumption could be right lack of air could cause a smoldering fire. You have any problems getting the stove up to temperature? But black smoke.. hmm green wood or seasoned wood? I notice a heavy load of green wood on a large fire will create almost a yellowish smoke but not black. You getting drunk and loading tires in a night? Ha
Last thought, if you are bruning only wood nothing with possible chemicals like treated wood, railroad ties, or oil saturated material it can only be your burning something that this tied to inside your boiler not good
It sounds like your wood is outgassing faster than it can be burned. I would try putting in some wetter wood to slow it down or find a way to get more air over the fire and less under.
RSI ...bingo ...I pulled the fan off the door I'm burning 3year dry spruce in the round 6" across to 16across I blocked off two sides of the airway to the chimmy trying to keep the heat in the boiler ...it is working and Im burning less ...but the black smoke is even a bit much for even for me lol
I'm a bit confused so is the issue is too dry of spruce? How often do you have to fill the boiler? Not many hardwoods available in Alaska?
Birch or spruce, and we also have spruce and birch 😅 seems it wants /needs a bit of over the fire air to burn off more of the gasses in the smoke...
