Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Portage & Main => Topic started by: blmike on January 20, 2016, 06:38:11 AM
Title: moisture out chimney
Post by: blmike on January 20, 2016, 06:38:11 AM
This is my first post,2840 has been running for 2 weeks.  I have water drip out chimney clean out,i have brown ice sickles hanging there.b Smoke at fill up-if the fan is on it is not bad but you have to be fast or it gets HOT fast. If I fill it like they say, I cannot see from the smoke.
Has anyone added a length of chimney to get better draft?  :-\
Thanks, Mike
Title: Re: moisture out chimney
Post by: hondaracer2oo4 on January 20, 2016, 01:19:33 PM
Excessive moisture come from one place. Your fuel. What is the moisture content of your fuel?
Post by: RSI on January 20, 2016, 06:01:15 PM
What kind of wood and size chunks are you burning? Wood that is causing that much condensation the the exhaust usually won't burn that fast while loading.
Post by: tinfoilhat2020 on January 20, 2016, 07:51:19 PM
Yeap.....95% sure its your wood.....green wood or big round that are not properly seasoned are probably the issue.also what temps are u running and what is the current outside temp in your area???
Post by: blmike on January 26, 2016, 01:20:53 PM
My wood is cut and delivered in 14' in the spring,the next spring i cut it in 24".It is piled in a shed with tin roof,i have no gauge but never had problems with my inside stove or the boiler i used for 12 years.It only leaks when it is cold out - 30 to -10.I believe the problem is the draft fan drawing in cold air,which drops the water temp 20 to 30 degrees.The boiler i made i ran a vent pipe from the draft fan above the insulation and the roof so it of the boiler were the air was worm,never had this leak at the clean out.
Post by: Strawbale Builder on January 26, 2016, 06:14:54 PM
What are your set points? Try 185 degrees with a 10 degree dif . Also keep your ashes to no more than about 6" that will insure the refractory in the bottom gets hot enough to preheat the combustion air and keep the boiler dry.
Post by: blmike on January 26, 2016, 06:47:15 PM
It is running at 180 and some times it seems that it boils over,i have temp gauges that i can keep an eye on it now.It is 10 degree dif now.I keep the ash down almost to nothing.I hate the way it smokes,need a hazmat suit to fill the stove LOL.
Post by: Strawbale Builder on January 27, 2016, 07:42:33 AM
Are you taking the supply water off the top? Their manual has not been updated since they changed designs from a wet to a dry bottom boiler. If you are heating just one building you should taking the supply off the bottom left and return to the top right and make sure the pump is big enough to give proper circulation. If you have are heating two buildings just make sure the supply for both buildings come off the bottom and return to the top. To check turn your pumps around to see if the boiling stops, if it does replumb when you can and also bump up the temp to 185. For the smoke issue try starving the boiler a bit, use just enough wood to get you to the next charge time so when you open the door you have more coals and less smokey charcoal. Hope this helps.
Post by: timothy4140 on January 27, 2016, 08:01:17 PM
Hey, guys; hate too chime in, I am having the exact same issues... I have the 34-44 and everyone said my boiler would be undersized. Not the issue at all. Came home this evening to find mine boiling off again, 4-5 time this season... I think I lost a pump this time... I am at a loss. My manual said to supply - top; and return - bottom ports. My wood is well seasoned 4+ years - from a power line clearing. Supplying 2 buildings (house 3500 sq ft and 1800 sq ft shop). Running grundfos 26-99 to house and grundfos 15-58 to shop. I am located in Virginia (northwest).
Post by: Strawbale Builder on January 28, 2016, 06:43:35 AM
I am a P & M dealer from northern WI, the older manuals are wrong. Switch the supply to the bottom and return to the top, the boiling will go away. The probe for the aquastat enters the water jacket below the top of the heat exchanger so when the boiler is operating the aquastat will give you an actual reading of the water temp in that place in the water jacket but as the hot flue gasses move through the heat exchanger the water at the top gets much hotter. By dumping the return water on top you will cool the water enough to prevent boiling and also grab more BTU's. On our installs we put the pumps in the back of the boiler at the bottom supply ports so the pumps can never run dry.
Post by: tinfoilhat2020 on January 28, 2016, 07:00:43 AM
mine is the same way: supply on bottom and return on top
Post by: mlappin on January 28, 2016, 11:19:25 AM
Exactly how my G400 is hooked up as well. I also hooked the waste oil boiler I built the same way much to the consternation of my father, I have  a temp probe on a supply line for a differential controller and my Ranco high cutout is in the top in it’s own well, both read with in a degree of one another. So basically you get better mixing pulling of the bottom and returning to the top and eliminate any stratification.
Post by: Strawbale Builder on January 30, 2016, 10:09:33 AM
Hi blmike and timothy, have you had a chance to reverse your pumps? Don't do it if the pump is in the back of the boiler on the top port, don't want you to run it dry and burn it out. If any of the pumps are in a building try it, the boiling will go away then replumb when you can. Let us know if it works.
Post by: blmike on January 30, 2016, 10:18:01 AM
I was told by the dealer if you plum it to pull off the bottom and return to the top you also lose or drop the water temp by 20 degrees going to the house.
Post by: mlappin on January 30, 2016, 10:40:08 AM
Not if you have proper flow. I have gauges in my supply and return lines, the supply gauge will read within a degree or two of what the controller says that reads off the top. My waste oil boiler is the same, pull off the bottom and return to the top, the gauge on the bottom reads the same as the high cut out on the top.
Post by: blmike on January 30, 2016, 05:13:48 PM
I installed temp gauge,with high and low warning alarms.High is set at 190 and low at 120,one week and no alarms went off.
Post by: blmike on January 30, 2016, 05:15:59 PM
Has anyone added a length of stove pipe to try to get the smoke down when filling.
Post by: Strawbale Builder on January 30, 2016, 06:25:06 PM
I agree with mlappin. Also your water jacket is only 90 gallons, many boilers of the same btu output have 2 or 3 x's the volume so they can stratify more easily. I have been having all my customers take off the bottom for the last 3 years or so since this issue was first brought to my attention the first year the Ultimizer was introduced. It will work and you will get plenty of heat. Try it and let us know.
Post by: Strawbale Builder on January 30, 2016, 06:33:03 PM
Try letting your wood burn down a little more or you can open the ash pan door to get a draft going before you open the firepot door. Do not forget to close your ash pan door when you finish loading or you will soon be hearing a train whistle!
Post by: blmike on January 31, 2016, 03:54:57 PM
I will wait till spring to change the hoses around,it is working for now.
Post by: patvetzal on July 26, 2016, 12:39:37 PM
Well, your wood isn't going to dry much while it is sitting as 14' logs. And once it is enclosed in a tin shed you won't get much circulation either.   I cut split and piled a bunch (4 bush cord) in one of our sheds once. Lots of eager help so it took a day. I left it in the shed from April until fall and then tried to burn it.....found that the birch and maple had gone mouldy, from the trapped moisture.
When we burn damp wood in our OWB we get a build up of creosote that screws up the draft so the smoke comes out the door. When we clean it out, all is good for a while.  We already have ten feet of chimney, just more to clean out.
