All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: CRJR on March 01, 2016, 11:22:42 AM
Title: A reminder
Post by: CRJR on March 01, 2016, 11:22:42 AM
A little reminder of why not to put your boiler in a building and then blaming the manufacturer . Pure ignorance and stupidity of the owner not manufacturer or installer. Granted the installer should've advise against it but still not his fault in my opinion. I hope the video Play's.
https://youtu.be/q5aJIzsja6s
Title: Re: A reminder
Post by: mlappin on March 01, 2016, 11:33:20 AM
So the homeowner doesn’t have insurance? If the insurance won’t pay did the homeowner check with the insurance company to see if the indoor install was okay?
$125,000 for the stove and wood shed??
They had to have something else attached to the wood shed and lost that building as well?
A friend lost a hoop building full of hay to fire last summer, the one right next to it also caught.
He put up two more, far enough apart to make sure if it ever happens again they both won’t go.
Post by: CountryBoyJohn on March 01, 2016, 11:54:42 AM
I've spoken with Heatmaster about this video.   There is a ton of half-truths in this video.  Lot's of one-sidedness.  If you'll notice, his comments are disabled as well.  He made a stupid decision and tried to blame Heatmaster.  When they didn't do what he wanted, he made a propaganda video.
Post by: mlappin on March 01, 2016, 11:56:22 AM
I usually ignore videos with the comments disabled, most likely they already caught a lot of flack over the video so disabled comments. Or deleted the original then reposted it with comments disabled.
Post by: shepherd boy on March 01, 2016, 01:14:38 PM
I know about this situation. It's not like it sounds. The stove was not installed by Greg. Greg was never in the house. The owner had contracted the house and setup with contractor and was not present enough at construction to know who did what and had a caretaker taking care of the fire. The fire appears to have started under the stove and was operational error. $125,000? Insurance? Lot of stuff doesn't make sense, sounds like extortion. However outdoor stoves need to outside. They are steel and water, the only way you can burn one up is get your fuel too close and have an problem.
Post by: mlappin on March 01, 2016, 01:36:37 PM
I wondered if maybe somebody removed ashes or something and left a coal lying around.
Post by: shepherd boy on March 01, 2016, 03:04:59 PM
 Exactly! That easy to do and it appears that is what happened.
Post by: fireboss on March 01, 2016, 05:08:06 PM
I don't think this post should be up ! It's just a bashing thread we don't need it on here
Post by: mlappin on March 01, 2016, 08:40:44 PM
Possibly, but its also an excellent reminder of why a Outdoor Wood Boiler is exactly that, an OUTDOOR wood boiler.
If you insist on enclosing it, then be VERY careful about any stray embers/sparks flying around and also be careful with your ashes.
Post by: willieG on March 01, 2016, 09:24:02 PM
my home made stove is installed in an outbuilding has been since I first built one in 2002-3 winter season
to me both the building and the stove are replaceable and neither are insured. I like having about a half years wood indoors and dry. I like being out of the elements to load the stove. I keep half my wood inside and half outside and burn from the outside pile as long as the weather is decent enough and the snow has not covered my pile. when the weather is bad I use the indoor wood. If I was to have the price of a new gasser in a stove I may not have put it inside but I don't, so I do.
It is important to make sure that the floor is clean around the stove and if a coal gets out the door you scoop it back up and it is always a good idea to look back and make sure the door is closed before you exit the building
Post by: shepherd boy on March 02, 2016, 04:13:35 AM
What willieG is saying is true, as an owner we may choose to take a risk in exchange for the benefit. Then we need to take responsibility. But as an installer we try to make sure we don't take on undue liability. I hesitate to do any maintenance and repair to any outdoor furnace inside a building as any accident may be placed back on the last person that indicated the furnace was in operational condition. And never install a unit inside a building. A sale is not worth the risk to me. I have been asked by an insurance company more than once what was the cause of the fire. Don't ask me to lie. But if you want the building , take the responsibility for safe operation, liability for accidents and assume their could be a malfunction in the stove itself. I have went back to a costumer and found a building with stove, chainsaws, gas, tools, lawnmowers and even tractor and farm equipment in the same building. More risk than I want to be close to.
Post by: coolidge on March 02, 2016, 06:06:21 PM
I built a shed for my boiler and too hold four cords, I was aware at what could have happened, no way I would have gone back to the OUTDOOR wood boiler manufacturer if something would have happened.
My homeowners insurance guy thought it was a good idea, I looked at him dumbfounded.
Post by: farmboythegreat on March 02, 2016, 06:37:53 PM
125 grand ??? was the fricking thing gold plated ???
Post by: schoppy on March 02, 2016, 10:39:35 PM
My G400 is about 1/3 inside my shed and 2/3 outside. All steel shed (carport style only with squared off corners), cement floor, 2 roll up doors to load firewood and firewood kept at proper distance from boiler. Ashes kept in steel garbage can and allowed to cool before disposal.
Shed holds almost a years worth of wood (average year) and is kept dry and out of the weather. Yes, you need to use your head and always ask what if?
Post by: mlappin on March 03, 2016, 06:35:52 AM
I plan on placing a roof over mine eventually, and just a roof, four open sides and steel shingles. Barn tin on each end to close in the rafters and underneath on the ceiling, then will borrow my uncles 8 foot flashing brake to wrap the poles or cover any exposed wood.
Post by: hockeyguy on March 04, 2016, 10:19:25 AM
Thanks for posting this. My boiler is in a shed as well, so it's a good reminder to be careful. I always keep the floor swept clean in front of the boiler and cover the floor with snow when possible in case embers come out while loading. I also have sheet metal on the wall behind the boiler in case the chimney T cover should come off.
Post by: hoardac on March 05, 2016, 05:36:57 AM
You just got to be careful if they are inside. Just like having a wood stove inside you have to pay attention and be careful with the coals and where you keep you firewood.
