All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: ralphxj on March 14, 2016, 06:49:55 PM
Title: Heated floor options
Post by: ralphxj on March 14, 2016, 06:49:55 PM
Getting ready to give our upstairs bathroom a facelift. Its a small room, like 50sq/ft including thr vanity, tub and small closet. Part of the project is to put down a tile floor. The bathroom is currently heated with a 30 in baseboard, hot water heat, that doesn't put off much heat. I'm thinking about heating the floor since it's such a small space, I'm redoing the floor anyway, and the room could use more heat.
The bathroom is the last room on the upstairs loop that includes 3 bedrooms. I want to be able to install something that will run in line with the loop I have and not have to worry about running a new loop or tempering valve or anything like that. I'm not sure if I should leave the 30in baseboard unit as well as the heated floor, or just the floor?
I have access to almost all of the floor from the bathroom below it, and have no problem cutting up the floor in the other spot and putting it back down after so I can heat the whole area.
The area I would be heating would be 6ft of joist (16in on center), 8ft of joist (16in) and then 8ft of half a joist (8in) so it would be a fairly short run.
Thoughts? What products should I be looking for?
Title: Re: Heated floor options
Post by: mlappin on March 14, 2016, 06:53:59 PM
Sounds like you need to get acquainted with Ultra Fin.
The only problem I see with just running one loop you may have to play around with how many pieces you place under the floor to avoid under or over heating the room.
Another possibility would be to add a 3 way zoning valve under the floor and have a thermostat in the bathroom to control the zone valve.
Post by: ralphxj on March 14, 2016, 07:11:43 PM
Was looking at Ultra-Fin Plates earlier, glad to see I was on the right track. Anyone know where I can find a smaller quantities then a box of 100?
Adding or removing plates wouldnt be a big issue if I need more or less heat as long as they come on and off fairly easily since I have access from below.
We keep the upstairs around 70 and the door to the bathroom is always open, so too much heat would only be an issue if the floor was too hot to walk on.
Post by: 12valve on March 15, 2016, 07:19:23 AM
I like Ultra fin I did a 20x 20 room on its own loop.  Works great but you need to insulate underneath.  Call Ultra fin I think they only sell it in 100 a box but maybe they can help you out.
Post by: mlappin on March 15, 2016, 07:21:17 AM
Can always buy a hundred then sell the rest on Ebay, Craigslist or even list em here.
Post by: coolidge on March 15, 2016, 11:00:04 AM
How many do you need? I have some left over from a project but they are for 3/4 pipe.
Post by: ralphxj on March 15, 2016, 11:04:06 AM
In doing some thinking, I might need the extras for a future kitchen remodel, so I will probably get the box of 100 and just hand on to them.
What PEX works best? I see the list of recommended brands, but can't find most of them easily available  (on amazon.com) or they are crazy expensive for a big roll. Will any PEX that is labeled for radiant heat work?
Post by: coolidge on March 15, 2016, 12:46:17 PM
Supply house.com.  Pex al pex
Post by: mlappin on March 15, 2016, 01:52:58 PM
Not so sure about pex al pex anymore as it’s all chinese. Stick with a name brand with an oxygen barrier if it’s closed loop. I’ve even heard some of the “good” pex al pex that is getting some age is starting to fail.
Post by: ralphxj on March 15, 2016, 02:21:42 PM
Looks like I have it all sorted out. I must have had a filter on or something earlier, couldn't find any of the listed PEX for less then $200 a roll! Fixed that and found a couple options, will be buying enough for the bathroom and kitchen so I'm ready when that project comes along.
Post by: schoppy on March 16, 2016, 09:45:41 PM
Where do you live and how much do you need? I have multiple sections of varying lengths of 1/2" oxygen barrier left over from my shed.
Post by: atvalaska on March 18, 2016, 07:14:00 PM
I'll have to look ...do we have a forsale thread here????...
Post by: schoppy on March 18, 2016, 11:13:59 PM
ralphxj, do you know how many feet and what size your looking at?
I don't know what shipping would cost but I have multiple different lengths of 1/2" O2 barrier pipe I don't have a use for and you could have it. All you would have to pay is the shipping costs if it is long enough for your needs.
Post by: ralphxj on March 19, 2016, 04:51:56 PM
I would have to double check, but I believe I need between 30-40ft maybe? My runs are 6ft, 6ft, 8ft, 8ft and then how ever much I need for the 4 turns between each 16in section of floor joists.
Post by: schoppy on March 19, 2016, 10:52:36 PM
I have a 41' piece and several shorter that you are welcome to have. You can always join them together with crimp couplings or sharkbite push fittings if need be.
Where are you located? Would have to check on shipping prices. My tubing is Nibco brand, 1/2" oxygen barrier. I haven't had any problems with my installation.
I checked on supplyhouse.com and a 300 ft. roll of 1/2" oxygen barrier goes for $99.95 and ships for free. I am in south central Wisconsin.
Post by: schoppy on March 24, 2016, 11:14:52 PM
ralphxj, checks in the mail! Ups picked up the pex today so it is on it's way.
Good luck with your project.
Post by: ralphxj on March 25, 2016, 06:55:59 AM
Thanks so much!!
Post by: ralphxj on March 29, 2016, 06:49:04 PM
schoppy, got the pex today, thanks so much!!! Ultrafins will be here tomorrow!! A combination of not realizing they didn't come with the hangers and being on a tight budget and not wanting to spend an extra $50 for hangers, I found another solution.
5 minutes of cad, some scrap steel and about 15 seconds each on the cnc plasma table and I have myself some custom hangers. They need cleaned up and then bent and they are ready to use. They are setup so I can use them at either 2in or 3in from the floor. I will use heavy duty zip ties to attach the pex:
