Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Central Boiler => Topic started by: jd40mo77 on November 26, 2016, 02:10:24 AM
I just now tried lighting a fire in my 5036 we got new in december 2012 and the temp controller flaked out and ended up displaying - - - instead of numbers.....
https://www.amazon.com/Dwyer-Digital-Temperature-Switch-Display/dp/B009P8K3DM?th=1#detail-bullets
I found this controller and was wondering if anyone had tried it?
http://www.thermomart.com/digital-automatic-temperature-control-instruments?product_id=90
Also thinking about buying extra damper solenoids and found best prices here
https://www.outdoorwoodfurnaceparts.com/proddetail.php?prod=S240
If the temp range is correct, I don't think it will work for an OWB as the temp range says it is 32-158 degrees Fahrenheit.
