All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: Dirtslinger on November 09, 2008, 10:14:46 AM
Title: Water to forced air
Post by: Dirtslinger on November 09, 2008, 10:14:46 AM
Has any one put there heat exchanger on the cold air return side of forced air furnace?
 If so how well does it work.
Just bought a woodmaster 4400
Title: Re: Water to forced air
Post by: yoderheating on November 09, 2008, 06:17:36 PM
 Depends on what kind of furnace you have.  If you have air conditioning you will have to put in a zone valve.
Post by: willieG on November 09, 2008, 07:03:24 PM
i am not sure what your ductwork is like, but it is recomended that you "fill" your ductwork with rad in order to stop air flow from going around your rad and not through it, most ductwork i have seen has a larger return duct than the other, if so you will need to spend more money on enough rad to fill the bigger cavity, also it is wise to have your rad on the "clean side" of your filters so your rad is not collecting the "dust bunnies" that your filter will normally capture
Post by: Dirtslinger on November 10, 2008, 06:21:07 AM
My furnace is a arcoaire with no air cond.
Post by: Dirtslinger on November 10, 2008, 06:25:17 AM
The only reason for putting it on return side is that my plenum small if I do put it on the cold air side my filter will be in front of it to stop the dust bunnies
Post by: R W Ohio on November 10, 2008, 07:46:47 AM
I have a coworker that had to install his in the return and has had no problems to date. The hot air across the blower motor was a concern but as of now it has not caused any problems. I will tell you to make sure that the water goes into the bottom of the coil and out the top in order for it to work.
Post by: Dirtslinger on November 10, 2008, 03:30:25 PM
I was looking at that to and my circuit board is in there so I might have to change my mind again :bash:
Post by: yoda on November 10, 2008, 08:27:24 PM
my coil is on the "hot" side but I have my hot water going into the top of the coil. Should I change it around? if so why? thanks
Post by: R W Ohio on November 11, 2008, 11:02:42 AM
I have been told that it is hard for the pump to push air from the top down through the coil,thus you could end up with an air lock in the coil and not be able to bleed it out.
Post by: yoda on November 11, 2008, 06:23:26 PM
 Makes sense, thanks
Post by: yoderheating on November 17, 2008, 07:34:15 AM
 If your pump can't push the air out of the coil your pump is undersized. The suppy should be on the side the air is blowing toward. So, when installing in the return, the suppy sould be on the furnace side, and when installing on the supply side the water supply should be away from the furnace. This will make the air warmer. As the air flows through the coil,  it reaches warmer and warmer water.  If you put the hottest water first, the rest of the coil does very little to raise the air temp.
Post by: jcappe on November 17, 2008, 08:19:48 AM
Mine is in the cold air section of my duct work and it works great.  I basically put it where the furnace filter was and moved the filter.
Post by: Acecooper on August 28, 2010, 12:47:25 AM
My furnace also has air conditioning. I don't know how it works on yours but mine us working properly. It is hard to give a suggestion since you haven't supplied a complete description to what you are using, try to post a picture so we can visualize it.
Post by: juddspaintballs on August 28, 2010, 07:43:19 PM
The system I am currently installing via the help of my HVAC father-in-law has the AC coil on the supply side inside of the air handler, then the water/air HX in the plenum, and the backup electric heat coils on the return side.
Post by: yoderheating on September 03, 2010, 09:03:26 PM
 The reason you have to be careful with a furnace with A/C is because you do not want to pull hot air across a A/C coil when the A/C is running. This has the potential of damaging your compressor. This may sound like a strange scenario but it has happened.
Post by: bruey on September 20, 2010, 08:51:23 PM
what i was told about using the cold air return is don't set your thermostat above 175. a friend of mine in the furnace industry said anything more than that could damage the wiring and boards in the furnace. anything below that no problem.
