		Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Hawken Energy, support only => Topic started by: Radio Tech1964 on January 18, 2018, 10:46:21 PM
				Does the aquastat bulb use a well in this model or is it direct immersion? Mine seems a little flaky lately so in case I have to make a emergency swap I'll know what to expect.. "To drain or not to drain that is the question" :o
wt
				I'm pretty sure it's in a dry well, the Globals and PW's were that way and they were similar units.
				Thanks! That's what I was hoping for.  Probably replace it with a Ranco when the weather gets a little more agreeable LOL
				Here is a ridiculously good deal on a ranco.
 https://m.ebay.com/itm/Ranco-ETC-111000-000-Digital-Electronic-Temperature-Control-120-208-240-VAC/263428578483?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20161006002618%26meid%3D9e23e4d1d64b413f85453ec7a177562a%26pid%3D100694%26rk%3D1%26rkt%3D30%26sd%3D152857363324&_trksid=p2385738.c100694.m4598
				Yeah, a Ranco is a much nicer control . Good idea.
That's crazy cheap..  wow.. I got some inkbird temp controls off of Amazon for about $17. They work quite well to run a stove but need a specific slot to clip in like a Love control.
				I know. I had to look at the listing multiple times to figure out what I was missing. I thought about buying them all and flipping them for $50 each.
				wow that's cheap
				Feedback doesn't look so good for that ebay seller.
				I plan on replacing mine this summer providing it doesn't go totally off the charts before then.
				don't buy from that seller...
				Hi,
You can purchase parts for your Hawken Furnace at Hawkenstore.com.
