Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => HeatMaster => Topic started by: Farmer Rob on January 21, 2018, 10:06:43 PM
Hello group and does anyone have one of the Multi fuel boilers,if yes what do you burn other than wood in them?
I've burned coal and sawdust mixed with the firewood in an MF unit. That's been 5+ years ago. Worked great .
Got a Heatmaster C series on house and one on our multipurpose building. burn wood and coal and the rest I don't tell.
Thank you guys for that Info and I will not ask what that stuff might be which you do not want to mention.lol Is the door big enough to fit a square bale of hay/straw through it?Also what kinda burn times do you get with wood when is (Cold) dead of winter?
I have a C375 as well, (very similar to the MF7000E) and have tried a little bit of everything. I load for 12-14 hour burn times, but if I stacked it full of oak I could get probably 36 hours at -20F heating 5200 sq ft. Stacked it full back in November to see if I could leave for the weekend deer hunting and it lasted 4 full days, but it was also 20-30 degrees.
I tried coal and it's fine, but was not impressed with longevity or the smell
1 sack of compressed wood pellets for pellet stoves and it seemed to burn very well, just the holes in the grates were a little big and let some of the pellets fall through into the ash pan
1 sack of 20% MC corn which also did well but also fell through the grates and stinks like hell
1 sack of corn still on the cob did well but a lot of ash and again the smell was bad
3 small squares of straw, yes they fit through the door, but there wasn't much heat in it. A lot of ash. Seemed to burn a lot like cardboard and was tough to control as it was warm when I tried, would probably do better in the cold but doesn't last very long. I think corn stalk bales would do well but nobody square bales them around here
I prefer the wood myself, but it'll burn anything you throw in it. I won't burn pallets or anything with nails or plastic for fear of plugging up the shaker grates. I toyed with the idea of a small sheet of fine mesh over the shakers for corn or pellets but they're both too expensive here to bother making a habit of it
We had a customer tell us they incinerated a 500 lb. steer in their MF20,000e. Said it smelled like roast beef for a few days.
