All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: mj on October 17, 2018, 09:00:24 PM
Title: Thoughts on buying used logstor
Post by: mj on October 17, 2018, 09:00:24 PM
I have a local farmer that is selling a used length of logstor. He previously had the cheap foil wrapped pipe and replaced it with this logstor and 2yrs later he had an accident and couldn't cut wood anymore so he dug up the thermopex and scrapped his old central boiler bc it had already been repaired multiple times. He dug it up last year and it has been sitting inside his barn since then. The lines have not been capped off so if I buy it I was planning on flushing both lines out with a garden hose before I hook it up. I know I need to look the entire length over to make sure he didn't puncture it with his hoe but is there any possible issues using used pipe?
Title: Re: Thoughts on buying used logstor
Post by: mlappin on October 18, 2018, 10:10:06 PM
Don’t think I’d pay more than half of new, it could probably be repaired long as he didn’t completely mangle it. Some adhesive silicone and a large piece of heat shrink
Post by: wreckit87 on October 20, 2018, 07:06:04 AM
Do you know how it was removed? If actually carefully dug and removed, I wouldn't hesitate for a minute to use it if the price was right. But if he hooked a chain on the end and ripped it out like most do, there's likely a ton of cracks in the foam now and it's separated from the tubing, so any water that lands on an exposed end or through any small puncture in the jacket will run down along the tubing and cause troubles. I gave some used Logstor to a neighbor last fall who had fallen on hard times and needed some heat; it was removed in the latter fashion and was very fractured up inside, but the jacket was free of any nicks and we took good care putting it back in and sealed both ends with spray silicone. It works very well for him
