Author Topic: Changing light bulbs  (Read 13263 times)
Ridgekid
Re: Changing light bulbs
« Reply #15 on: August 30, 2011, 12:57:41 PM »
LED's are too long for the enclosure. I opted for 60W soft white bulbs. They won't be on all the time anyway.
gmviso
  • OWF Model: CL5036
  • Northeast Indiana
« Reply #16 on: August 31, 2011, 04:10:57 PM »
Clear or frosted 60W is 60W. Heat difference should be negligible. 40W Clear may be a good idea!
Central Boiler CL5036
MTJAG
  • OWF Model: CL5036
« Reply #17 on: September 06, 2011, 05:37:29 AM »
Sam's Club has the LED bulbs that fit the CL5036.  I did exchange the ones that came with my unit since I am off-grid solar and they work fine with plenty of light and virtually no consumption of power.  LED's as a rule are more directional, but when it is pitch black, they provide a very white light.
gmviso
  • OWF Model: CL5036
  • Northeast Indiana
« Reply #18 on: September 06, 2011, 08:52:59 AM »
I saw those bulbs at Sam's Club yesterday. A two pack was about $20 I think. They were only 2.5W though. Not sure if they are equivalent to a 40W incandescent. I think you need 4 to 5 watts of LED to be equivalent to the 40W incandescent.
MTJAG
  • OWF Model: CL5036
« Reply #19 on: September 09, 2011, 03:05:00 PM »
No, you are right, they are not equivalent in lumens to 40W "heat lamps".
dirtryder
« Reply #20 on: September 12, 2011, 08:09:31 AM »
I just put up a 12' 4x4 PT pole with a standard house spot light like the ones that are normally mounted to your eves.....it has a double light set. I tapped a wire from my boiler elec feed to the pole, through a switch, and I have all the light I could ever need. Not expensive, not much work to do.
I also have my boiler feed on a ground fault breaker (for hot tub heating safety) and everyone know's how "touchy" they are for tripping and have never had an issue.
Ridgekid
« Reply #21 on: September 12, 2011, 09:59:27 AM »
dirtyryder- Great idea as I've thought about doing the same thing. I was thinking putting a street light (low wattage) with a light sensor, now that I have a webcam going. This way you can keep an eye on my OWB while I'm sleeping.  :thumbup:
Ridgekid
« Reply #22 on: September 24, 2011, 06:54:15 AM »
This is just a follow-up.
I installed a dusk to dawn light last night, powering off the OWB feed. I put the 12-2 wire in plastic pipe and buried it. The unit is on a 20 AMP breaker, so the addition of the light should have little effect of operation. It's 100W.
< web link under user name will give you a 24 hour view through my weather station. (Updated every 5 minutes)
