Author Topic: Pump not running now  (Read 8209 times)
froggy22
« on: September 07, 2011, 06:17:00 AM »
Well just as I thought,   I went out to look over the furnace this morning and noticed the circulating pump was not running.   I thought it was getting too hot to touch.  It is a taco 0011, which was recommended by salesman.  My setup is stove a couple feet lower than basement floor, pipe under ground 20" then up a wall 8' over 8' and back down 2 1/2- 3' to exchanger.   I have a 90 out of stove, the pump,!" plex connector strait , 75 ' of 1" pex to a valve, and a 90 degree connector,  exchanger16 x 18", 90degree shark bite 90, valve, return pec pipe, back to valve at boiler.
Could I have just got a bad pump, or wrong pump, or flawed design that I mentioned above.?
froggy22
Re: Pump not running now
« Reply #1 on: September 07, 2011, 06:22:43 AM »
Pump ran for about 20 hrs(I say 20 hrs but I was asleep 6 of them).   Pump was pumping water, had good heat out of my vents before bedtime. I don't see what could have caused the pump to fail...
froggy22
« Reply #2 on: September 07, 2011, 06:52:15 AM »
Went down after my coffee, and it was on,  it is so quiet I must have not been awake enough first thing, or it my have been off.  I'll keep a eye on it.   :o
« Reply #3 on: September 07, 2011, 07:18:52 AM »
Keep an eye on it, I was afraid you had air in it and it was overheating
froggy22
« Reply #4 on: September 07, 2011, 07:31:29 PM »
I did the return water test and have 10 gallons a minute of flow,  I will do an amperage reading on it soon to see what the current draw is.  In the mean time my fingers are crossed.
