Pages: 1 2 [3]
Author Topic: Starting to build !  (Read 30536 times)
jackel440
Re: Starting to build !
« Reply #30 on: November 06, 2011, 11:43:03 AM »
Looks like your almost there.what's your plan for the outside?
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
newmod
  • OWF Brand: HOMEMADE
« Reply #31 on: November 06, 2011, 11:55:57 AM »
Jackel,
     i plan on insulating with 2 inch rigid foam board and also wrapped with some other sort.  Any advise would be greatly appreciated.   Going to use the RANCO 111000 aquastat but still need to choose a thermometer that i can wire in and have the remote head in the house.  Indian summer is running out soon here.
     For the outsite I need to weld some sort of frame to the Waterjacket so I can mount the steel siding
     The door latch wasn't what I was planning on but with the t-handle it is DEFINETLY gonna seal the door.  The door warped a little from all the welding, no big deal, just so there is no air leakage into the firebox.
Newmod
« Last Edit: November 06, 2011, 11:59:17 AM by newmod »
jackel440
« Reply #32 on: November 06, 2011, 12:57:54 PM »
The more you can insulate the better off you will be.
Now I used just regual fiberglass bats on mine.Seems to work well.When it snows it doesn't melt off the top.
Make your frame as big as you can so you can insulate as much as possible,and have it so you can take pieces off parts that you need to get to it in a pinch, if you have to work on it.
New Holland LS170
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
rosewood
« Reply #33 on: November 07, 2011, 05:36:40 PM »
i would go with the fiberglass,the 2''board is only about r 20 or less from what i have seen unless you know of something different.plus fiberglass will take alot of heat from exhaust where as foam might burn a bit.
Airgap
« Reply #34 on: November 07, 2011, 08:11:30 PM »
Thanks for the pics Newmod...OWB looks good so far... I'm envious of that shop too by the way! >:D
Keep up the good work, and keep takin pics...
newmod
« Reply #35 on: November 08, 2011, 07:05:25 PM »
Airgap,
     Thanks.  Ya the shop sure comes in handy.  It is a terrible mess, building kitchen cabinets,  OWB, and everything else in there.  Gonna be cold this winter though. wont have it heated until next year.
R W Ohio
« Reply #36 on: November 16, 2011, 04:08:33 PM »
Todd,
Ready to fire it up soon?
RW
R W Ohio
Canal Fulton,Oh.
newmod
« Reply #37 on: November 25, 2011, 06:43:32 AM »
Well we slowed down on the build for a little while.  Pressured it with 5 lbs of air.  found some pinhole leaks,  when trying to grind and reweld we just chased the pinholes for what seemed like hours.  Finally got it patched and put water in it found 1 more leak, fixed it.  It was gonna be done today but I got shafted in to working today.  IT WILL BE DONE TOMORROW !!!
Newmod
Pages: 1 2 [3]
