Author Topic: should I insulate door ??? HOW ????  (Read 7047 times)
newmod
  • OWF Brand: HOMEMADE
« on: October 26, 2011, 08:54:41 PM »
JUST AS POSTED,  I am at the point where i am trying to get the door done for my wood burner.  Should I insulate the door or not.  It has been a pain trying to find high temp insulation for it.  I need some input.  Thanks
peacmar
Re: should I insulate door ??? HOW ????
« Reply #1 on: October 26, 2011, 10:24:14 PM »
Insulation will help efficiency if you don't build a water jacket door. You can also make your own castable refractory for very cheap with home improvement store materials that will sustain 2000 degrees.
Check out
http://www.backyardmetalcasting.com/refractories.html
I enjoy casting aluminium and hand forging from time to time and stumbled across this a while back and the stuff holds up to the secondary burn temps of the "gasifier campfire" I put together with the help of my nephew. The stuff has great insulating properties also if you add a little extra perlite and is tough as nails once it cures. May be a viable low cost option....?
jackel440
« Reply #2 on: October 27, 2011, 07:36:40 AM »
I used K Wool which we use in heat treating furnaces.I got it from our refractory brick supplier.do a search for kwool or a local refractory dealer.
You definatly want to insulate your door.if not you will have heat loss,door warpage.then sealing issues with your door gasket.
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
beeman
  • OWF Brand: homemade
« Reply #3 on: November 06, 2011, 08:30:11 AM »
peacmar would you send more info on building my own this would be grate for my scraping
