Author Topic: Problems with plate exchanger  (Read 14868 times)
tulenutn2o
  • OWF Brand: HeatSource1
  • OWF Model: Earth Energy 190
Re: Problems with plate exchanger
« Reply #15 on: November 01, 2011, 08:25:12 PM »
I really don't understand the fuss about heating the water and storing in tank. Any heat "loss" is "lost" inside the house to help heat it anyway. I use a sidearm and no complaints here.
donahuej
  • OWF Brand: American Royal
  • OWF Model: 7300
« Reply #16 on: November 06, 2011, 06:42:11 AM »
Ohio,
You need the pump to continusiouly run to provide hot water from the plate set up.  A side arm will work off off convection and naturally move the hot water up.
Dirty,
My 50 plate is after my water tank and works fine.  I have 1 1/4 horse sumbersable pump that moves my 55 degree well water...Water is hot  :thumbup:- but not so bad I worry about my kids getting scalled, they are older and know better - so no mixing valve.  If I were doing this for others I would most likely go the Yoder route.  Safer as the tank is a big fat hariy mixing valve.....
