Pages: 1 2 [3] 4
Author Topic: hooking thermostat to a oil fired furnace w/owb  (Read 46826 times)
Re: hooking thermostat to a oil fired furnace w/owb
« Reply #30 on: November 11, 2011, 08:52:56 AM »
Is the furnace firing with the thermostat turned down?
It is hard guessing what the wires are from here. I think you will need to get a cheap meter to check which is which.
Another way that might work it remove the wire you think is the fan wire and see if the fan position still turns the fan on. If it doesn't then try making the furnace fire with it off and that should tell for sure that it is the right wire.
pintopaul
  • OWF Brand: wood master
  • OWF Model: model 434
« Reply #31 on: November 11, 2011, 09:05:34 AM »
rsi if you number is the 608 i sent another picture
« Reply #32 on: November 11, 2011, 09:10:34 AM »
Can you get that any clearer? I can't read the smaller words on it.
« Reply #33 on: November 11, 2011, 09:56:06 AM »
Looking at your pictures again, I think those rounds disks in the one picture may be the fan controller and the high limit. Try taking a piece of wire and jumper from one side to the other. If one of them has 3 wires on it try that first.
If that doesn't work then I will need to see a clear picture of the wiring diagram.
pintopaul
« Reply #34 on: November 11, 2011, 10:19:19 AM »
yes jumping the fan limit switch the one with 4 wires going to it , when i jumped it yes just the fan worked.
« Reply #35 on: November 11, 2011, 10:47:48 AM »
Then you can connect the relay module there and it should work. Use the same wiring I mentioned earlier and put the red wire to one side and the black to the other. (I think the 3rs wire in that group is brown, that isn't used)
pintopaul
« Reply #36 on: November 11, 2011, 10:52:14 AM »
ok what type of relay do i need to get ?
« Reply #37 on: November 11, 2011, 11:18:25 AM »
The one you mentioned in your first post should work. That is what I was getting the wire colors from.
pintopaul
« Reply #38 on: November 11, 2011, 11:45:33 AM »
so your saying to use the fan center honeywell part number r8285a1048? how would i wire that in? if you know how text me a drawing of it cause i work better from pictures haha
« Reply #39 on: November 11, 2011, 12:10:37 PM »
Does the Honeywell fan center have 2 sets of wires on it? One a black and a white and the other a red, a black and a brown?
pintopaul
« Reply #40 on: November 11, 2011, 12:54:08 PM »
ok on BOTTOM SIDE one side has blk and wht/ other side of BOTTOM has orange,brown and black.                                                    TOP SIDE has connections for r/c/w/g/y i got to check the voltage at the fan limit switch and its 110volts on either side. paul
« Reply #41 on: November 11, 2011, 01:01:14 PM »
The manual I founds lists the colors as red, black and brown.
You need to connect the white and black wires to a 120v power source.
Connect the black wire to one side of the fan switch and the orange to the other. Then if you jumper the R and W terminals on the honeywell module together the fan should start. If it does then connect those terminals to the same on the thermostat.
pintopaul
« Reply #42 on: November 11, 2011, 01:08:46 PM »
going to try it wish me luck (i might need it)
pintopaul
« Reply #43 on: November 11, 2011, 06:28:02 PM »
cant try till tomorrow went to our local hardware store i will not say there name (curtis lumber) but they had closed at 4 this would be a good town for a hardware store. oh wait the big one (lowes) closed because there was no buissness and that was only 14 miles away....... dam i want to get this hooked up. i'll let everyone know when i get it done. paul
pintopaul
« Reply #44 on: November 12, 2011, 02:50:52 PM »
rsi i tried to hook it up the way you said r to r     w to w didnt work if i leave red on red and i check the voltage on g or c i get 24 volts can i use one of these? i tried to call you when i was doing this but got an answering machine. if i can hook to one of the other lugs does this control center have to be mounted flat or can it be mounted on its side? thanks paul
Pages: 1 2 [3] 4
