Author Topic: Antifreeze for the Shaver  (Read 26325 times)
Re: Antifreeze for the Shaver
« Reply #15 on: November 17, 2011, 09:32:56 PM »
A small generator may be cheaper than the antifreeze
lugnut
« Reply #16 on: November 23, 2011, 09:15:09 AM »
Bull, this maybe all well  and good, but what if we're not home?  If it's a really bad storm, I don't expect any of my friends to be coming over  to bail me out.  Not saying they wouldn't but I wouldn't expect them to.
Right now, I'm looking at peace of mind on tow fronts...taking care of an expensive heating system: gas house furnace; finished lower lever; OWB and most importantly: the wife.  If the former fails due to my lack of putting in a back up, then the latter will be really hard to live with.
Lugnut
Jerry
Greenleaf, Wisconsin
Husquvarna 455 Rancher
« Reply #17 on: November 23, 2011, 12:33:39 PM »
LOL I agree with the last part
« Reply #18 on: November 23, 2011, 06:42:23 PM »
funny how we all seem to meet just "the right woman" and then they turn out to be all the same ;)
lugnut
« Reply #19 on: December 15, 2011, 05:00:19 PM »
I've thought this entire subject over and over in my mind...burned a few brain calories in the process.  I have decided that antifreeze is not going to happen because of the cost and that the antifreeze has to be changed out/refreshed every 2-3 years...depending I'm sure on something.  Instead, we're going to go with a whole house Generac generator.
The initial cost for the whole house generator will be a bit more than the antifreeze, but I will have that peace of mind knowing that "IF" we go away somewhere in the winter and the power goes out..within seconds the aux power will come on.  And a friend of mine says he' would stop over after work and check that the pump is in fact working.  IF the pump were to quit, and the generator is running, the heat from the house furnace will keep the pipes warm.
So now we just have to get through this winter without any sub-zero temps...I told my wife, that if for some reason we "had" to leave for a weekend this winter, if I know somewhat in advance that we're going in the deep freeze...hell I'll just drain the entire system.
Thanks again for everyone's input.
Lugnut
Jerry
« Reply #20 on: December 15, 2011, 06:16:02 PM »
I think the genset is a better idea than the antifreeze and I am sure you will too in a couple of years if not sooner.
mikenc
« Reply #21 on: December 16, 2011, 12:01:07 PM »
I have had a gererac for several years and have no complants. Starts when power goes off shuts down when power comes back on. I think you will enjoy the convience and piece of mind. Not to mention its nice having water,lights and heat  instead of sitting in the dark and cold when power is off.
tinner
« Reply #22 on: December 18, 2011, 08:20:22 PM »
Could you install another pump in the basement and wire it to come on with the back up generator? Just split the line and install a check valve in the every day line and the pump on the other side. Probably would have to install a timer on the power side so that it would not turn on for however long your gen set does it weekly run up. Although I do not believe it would hurt to have two pumps running for a short time frame.  This is something that I am planning on doing myself next year. But I do not have it all figured out yet.
« Reply #23 on: December 18, 2011, 08:47:57 PM »
No check valve or anything would be needed. Just put the second pump in series. A lot of people run 2 pumps all the time.
A second pump is a very good idea and I was going to suggest it if no one else did. Probably putting it on a strap on aquastat to turn on when the pipe gets cold would be best as it would be an automatic backup but then I would also put a light or something on it so you know the first pump died. (it would keep cycling on and off this way but get you through without anything getting cold)
tinner
« Reply #24 on: December 19, 2011, 06:19:31 PM »
Guessing that he does not need a second pump for lift. My thought was to keep them separated for easier servicing/replacement of the original. I like the idea of the aqua-stat. Good thinking!
« Reply #25 on: December 19, 2011, 06:22:42 PM »
You don't need to keep the spare running. Water flows through them ok when they are shut off. It is probably better for backup pump too because the water will probably keep the impeller turning a little and not have it frozen up when you go to start it.
tinner
« Reply #26 on: December 19, 2011, 06:47:15 PM »
AHHHHH
Understood!
That is why I am the new guy just getting ready to give things a go. And reading all I can.
Thanks!
