Author Topic: Black slime dripping from wood box and ash doors....  (Read 17575 times)
lugnut
« on: November 10, 2011, 09:09:53 PM »
Subject title reads like a really bad sci-fi movie.  Anyway, it will be two weeks since firing up my Shaver 250 for the first time and I've been getting this black slime oozing from both the wood box and ash door.  Any idea what it might be?  I thought at first maybe the silicone they used on the inside door for the gasket, but I would think that by now that should be set in as to where the door fits onto the gasket...could it be creosote?  Also it seems "wet" on the ledge of the wood box.  I suppose I should take pictures. ???
The "slime" just falls directly off when I run my glove under it...I am totally mystified to say the least.
One last question since I'm discussing the wood box door.  I have a "whiff" of smoke coming out of the closed/locked down door in the upper left corner.  I have turned the bolt in on the door mechanism, but this doesn't seem to make a difference.  I have black silicone caulk, but I don't think I can apply it now.  Most likely have to wait until the box is done burning wood and let it cool down prior to adding anymore silicone?  I feel that I "really" need to seal this door off as it is an air leak and air leaks in these furnaces are a no-no.
Okay, I'm going to tie my fingers up as they are babbling on now.  I look forward to any and all comments/ideas/suggestions.
Lugnut
Jerry
Greenleaf, Wisconsin
Husquvarna 455 Rancher
Re: Black slime dripping from wood box and ash doors....
« Reply #1 on: November 10, 2011, 09:22:36 PM »
Yes, most likely creosote. How wet is the wood you are burning? How long are you going between filling it with wood?
lugnut
« Reply #2 on: November 10, 2011, 09:44:56 PM »
RSI...the wood is perfectly dry by about 6-7 years.  I don't fill it again until there is hardly any wood left in the box.  I've gone out there on several occasions and opened the box door to find maybe a couple chunks of wood blackened but not spent and hot embers in the grating.
Thermostat on the rear of furnace is set at 150 degrees.  Am I filling it too often?  Or not often enough?
Jerry
Jerry
« Reply #3 on: November 10, 2011, 09:49:04 PM »
DO you pack it completely full? When you have more wood in there smoldering you will get more creosote than a smaller pile. If you are filling it once per day, going to twice a day with less wood may help.
lugnut
« Reply #4 on: November 10, 2011, 10:25:16 PM »
Hmmmmm...I've been wondering about this very same thing.  I actually do fill it twice a day, when I get up and head outside to the shop in the moring, I check it and fill it then.  Later in the evening say around 5 or 6pm before I go back in for the evening, I fill it up again and yes, I load it right on up.  So perhaps I shouldn't do that?  I should just put maybe half of what I've been placing in the box then?   and yes, I put I as much wood as I possibly can.
Ya know, the directions with any of these furnaces aren't the greatest in my opinion.   It's pretty much up to the buyer/user to learn what works or not.  This is why this site is just so gosh darn good.
Jerry
« Reply #5 on: November 10, 2011, 10:50:49 PM »
I guess it depends on how much heat you are using. I would try slowly cutting back how much you put in so you don't have it run out and need to to be re-lit.
If you are getting a lot of unburnt charcoal like chunks building up then I would try putting maybe half as much in and see how long that lasts.
lugnut
« Reply #6 on: November 10, 2011, 11:03:19 PM »
Thank you for your input.  I will do just that beginning tomorrow.  At first I was not filling it full of wood and I was feeding it for almost three times a day.  Then I thought, "maybe" I need to stuff the wood in there.  I mean it felt good when I would check the temps on the pex lines in the basement and they were hot.....which meant I was going to really enjoy my shower that night.
So I will try backing down with the amount of wood.  So come Spring I should be able to clean out most of that creosote from the furnace?  I know about cleaning the chimney, but I'm hoping I can clean the inside of the box and get all that black stuff out of there as well as cleaning the inside of the doors.  I know I will have to replace the insulation that I have between the inner and outer fire box door.
So any suggestions on how to take care of the "whiff" of smoke I'm getting out of the top edge of my firebox door?
By the way, do you reside in Wisconsin and if so where abouts?  Oh and do you have a first name?  I feel strage sending something to someone whose name is RSI.
Jerry
Ridgekid
« Reply #7 on: November 11, 2011, 05:38:25 AM »
RSI has given some good advice. I don't know the Shaver all that well other than what I read on their website. I know they boast about operating at lower operating temps than most OWB's because their water circulating pumps don't run 24/7 and have a smaller water capacity.
Doesn't anyone think 150F is a little low? I don't believe it needs to be as high as what CB recommends (185F) but based on the valuable information provided on this board I would think your creosote problem is occurring from overloading, short burns and low set point temps. I know you said your wood is well seasoned, but outside air is being drawn in for the burn. Unless you can get it to burn hot enough, I think your going to get this dripping.
Maybe when the weather gets colder and you get longer burns this will work better for you. I don't know, just thinking out loud......
JBG
« Reply #8 on: November 11, 2011, 06:10:09 AM »
I have a Shaver 290.  Try raising your temp. to 170 on 165 off.  That should take care of the cresote.
As for the leaking door.  Silicone a small piece of metal behind the latch on the stove.  I have not
had this problem  but I have heard this will work.  Good luck!!
Shaver 290
37 Ton Northstar log splitter
« Reply #9 on: November 11, 2011, 06:21:46 AM »
Welcome to the site JBG
Ridgekid
« Reply #10 on: November 11, 2011, 06:24:30 AM »
Ditto what Bull said! Welcome!
mikenc
« Reply #11 on: November 11, 2011, 07:39:50 AM »
wood can be 6-7 years and still have a lot of moisture. Has it been keep in dry under shed? Even covered with tarp it can have alot of moisture, if it has been covered all the way up. Only needs to be covered on top so air can pass through.
« Last Edit: November 11, 2011, 07:41:24 AM by mikenc »
JBG
« Reply #12 on: November 11, 2011, 10:39:36 AM »
Thanks all.  Cheers from Delaware!!
Shaver 290
lugnut
« Reply #13 on: November 11, 2011, 06:00:21 PM »
Ridgekid...I appreciate your thinking out loud.  My circulating pump is running 24/7 and I discussed this with Shaver.  They pretty much stated that if I only run the pump when the thermostat calls for heat, then the life expectancy of said pump will be shorter due to all the starting and stopping.  Less chance when the pump is running 24/7 and some of the guys around me run theirs 24/7 as well.  The tank in my unit is 230 gallons.
I've attempted to back off on the loading of the furnace, but not sure what defines "backing off."  I'm unsure what you mean by "short burns," please explain to the new guy.  I set the temperature on the rear thermostat back this afternoon to 130, so I suppose I will see what this does.  The cover on the blower motor is open a mere 1/4".
So am I to assume(and yes I do know what this word means.  LOL!) that once I get the auto damper, I should maybe set the thermostat up to 170/75?  And do I load up the furnace or back down on that as well?
I do apologize for all these questions, but I just don't know...but it's nice to know though, that I'm NOT alone with asking all these questions.
Look forward to the responses.
Lugnut
aka: Jerry
Jerry
lugnut
« Reply #14 on: November 11, 2011, 06:05:53 PM »
JBG......I just reset my temp on the rear thermostat again today down to 130 degrees.  I've read the Shaver owner's handbook from cover to cover and they really don't tell you much in there as to how to set the thermostat and at what temps.  You mention raising the temp to 170 on and 165 off....just how do I go about doing this?
Regarding the "whiff" of smoke at the door, I removed the bolt today and applied anti seize to it and then cleaned the dripping creosote off the inside of the door and gasket and (knock on wood) it was not "whiffing" this evening.
Lugnut  aka Jerry
Jerry
