Pages: 1 2 3 [4] 5
Author Topic: Shaver auto dampers  (Read 58074 times)
lugnut
Re: Shaver auto dampers
« Reply #45 on: January 09, 2012, 08:11:10 AM »
Hi lugnut
 can you send me the info and pictures of the auto damper you have and anyone elese have any pictures and planes
 Solenoid is attached to a piece of flat bar welded to back of boiler right above fan. Flat bar bent on 90 deg at end to attach solenoid. Turn buckle used to attach so you have adjustment to set fan opening.
How did you do that?  I asked if you could post a photo of where and how...and here it is and you're not even online.  It's....why it's magic!   :thumbup:
Lugnut
Jerry
Greenleaf, Wisconsin
Husquvarna 455 Rancher
Treewinder
  • OWF Brand: Shaver
  • OWF Model: 250
« Reply #46 on: January 09, 2012, 04:42:19 PM »
My factory setup
Ed
Eastern Shore of Va.
Shaver 250
041 056S 056M
MS660 070 084
CS670
CSM-Procut design & Baker 18M
Komatsu D-21-P
Kobuta B-6100
lugnut
« Reply #47 on: January 10, 2012, 11:05:38 AM »
Whoa....look at this.  I think you may have found my answer.  I think I might be able to turn the darn motor around and just shorten the plate that the solenoid in mounted to.  Why didn't I think of this sooner?  So, silly question here...how do you determine how to set the solenoid as to the proper opening?  as I already know..via personal experience, if it is kept from opening on its own the way it should, they burn up.   :bash:
The temps are to be warm today, wonder if I should take a stab at doing this now or waiting until Spring.  I'll go shower and think about it.
Thanks Ed.
Jerry
Jerry
mikenc
« Reply #48 on: January 10, 2012, 03:36:16 PM »
Hi lugnut
Lugnut
What can i say.  :)
Treewinder
  • OWF Brand: Shaver
  • OWF Model: 250
« Reply #49 on: January 11, 2012, 04:12:15 AM »
Thanks Ed.
Jerry
Jerry,
That's the way it came mounted from factory, except I rotated the electric motor (not blower) to better access the wires. When it opens it's about a third of being totally open.  Plenty for the cycle and shuts right when up to temp.
Ed
Shaver 250
041 056S 056M
MS660 070 084
CS670
Komatsu D-21-P
Kobuta B-6100
sergeant721
  • OWF Brand: Shaver
  • OWF Model: 250
« Reply #50 on: January 11, 2012, 07:10:41 AM »
What if you turn the blow on a 30 degree angle you would have to drill new holes on the flang
Treewinder
  • OWF Brand: Shaver
  • OWF Model: 250
« Reply #51 on: January 11, 2012, 04:18:46 PM »
Yes you would have to redrill
and depending whether Shaver used a true template or some shop guy to drill the holes, you may not even be able to rotate it 90 mor 180 without redrilling.
Ed
Shaver 250
041 056S 056M
MS660 070 084
CS670
Komatsu D-21-P
Kobuta B-6100
lugnut
« Reply #52 on: January 11, 2012, 10:51:11 PM »
One other thing I noticed, as I did re-drill the flange holes...the second grader who built my furnace did NOT get the pipe coming out of the ash box straight...so I have a bit of an angle to my pipe.  That was fun lining up as well.
Ed, they must have made improvements  ???  on my solenoid plate as it is about 8" long.  Yours is quite a bit shorter and no, I did not mess with it yesterday.  Cold weather and snow is approaching later on Thursday....today almost.  guess this will have to wait until Spring.  We'll see.  Say, can you measure for me the bottom of the plate to the top of it?  Maybe all I have to do is cut mine off.  But wait, did you order yours from the "factory" as optional equipment?  Mine was "supposed to come from the "factory" that way, but the third grader who does the work orders missed reading class that day. :bash:
Jerry
Jerry
Treewinder
  • OWF Brand: Shaver
  • OWF Model: 250
« Reply #53 on: January 12, 2012, 04:03:38 AM »
Jerry,
Came from the factory that way.   I will measure for you,  I'm away right now but will get it on Saturday for you.
Ed
Ed
Shaver 250
041 056S 056M
MS660 070 084
CS670
Komatsu D-21-P
Kobuta B-6100
lugnut
« Reply #54 on: January 12, 2012, 09:31:38 AM »
Jerry,
Ed
Saturday works well for me Ed...it and I are NOT going anywhere.
Jerry
Jerry
Treewinder
  • OWF Brand: Shaver
  • OWF Model: 250
« Reply #55 on: January 14, 2012, 12:52:48 PM »
Jerry,
8 1/4"  from bottom radius to top.
Ed
Ed
Shaver 250
041 056S 056M
MS660 070 084
CS670
Komatsu D-21-P
Kobuta B-6100
sergeant721
  • OWF Brand: Shaver
  • OWF Model: 250
« Reply #56 on: January 16, 2012, 09:16:42 AM »
What about the CFM's I just got the 75cfm moter and installed it.  Ive been finding that if the wood is a little wet the 75 cfm motor
seems to nock the fire down it seems to work better with the 50 cfm motor am I crazy ?
Treewinder
  • OWF Brand: Shaver
  • OWF Model: 250
« Reply #57 on: January 17, 2012, 04:34:31 AM »
You could just adjust the flapper if your going to burn green wood.  return it to normal when back to seasoned wood.
Ed
Ed
Shaver 250
041 056S 056M
MS660 070 084
CS670
Komatsu D-21-P
Kobuta B-6100
sergeant721
  • OWF Brand: Shaver
  • OWF Model: 250
« Reply #58 on: January 17, 2012, 05:43:31 PM »
Thanks Treewinder, ill try that how much of a gap 1"
lugnut
« Reply #59 on: January 17, 2012, 08:11:26 PM »
Jerry,
Ed
Thanks Ed......we have the same size plate.  So did I read y our post incorrectly...you flipped the electric motor, NOT the blower?  You've seen a close up of my blower/motor...I really don't have any choice but to wait until Spring to have a nipple installed in the pex line above the blower motor in order to raise it higher so I can flip the damper plate vertical.  Unless you ore someone else on here can come up with an alternative plan....  I do know that tomorrow, I have to go out a buy another 5" of plastic tube as I cut mine back a bit trying to modify the opening.
Jerry
Jerry
Pages: 1 2 3 [4] 5
