Author Topic: Baseboard noise  (Read 17654 times)
Baseboard noise
« on: November 13, 2011, 12:07:02 PM »
Hi all, You have been so helpful with helping me troubleshoot the problem of keeping fire in my OWB, I figured that now the fire problem is solved, I'd hit you up for some help with the baseboard noise in one of the zones in my house.
I have 3 zones, each operated by their own zone valves connected to seperate thermostats.  The zone in my bedroom is making a weird kind of sound.  When it calls for heat I hear what I call the usual ticking sound but that is short lived.  The other sound I hear from the baseboard, sounds like someone is constantly crinkling paper.  It is loud enough that it interrupts my sleep.  As soon as the heat is satisfied and the zone valve shuts down, the noise stops.  any ideas?
Thanks, Roger
beeman
  • OWF Brand: homemade
Re: Baseboard noise
« Reply #1 on: November 13, 2011, 01:21:42 PM »
take the front cover off the baseboard and see if thear is room for expancion or is it tite wall to wall ,you  might allso look behind the fin tube see if the paint has been rubed off like sand paper if the first no room end to end you just take a little out the second with the paint missing is from the fintube expanding and contraction rubbing the back or front of sheet metal they sell aplactic bushing that go on the fintube hangers that keeps the fintube centerd
Re: Baseboard noise
« Reply #2 on: November 13, 2011, 10:10:57 PM »
Are you sure there is no air trapped in it?
Re: Baseboard noise
« Reply #3 on: November 14, 2011, 05:35:44 AM »
No.  I am not sure that no air is trapped in it.  When I get a few minutes, I'll purge it in hopes of removing any air trapped air.
Thanks,
Roger
beeman
Re: Baseboard noise
« Reply #4 on: November 16, 2011, 09:48:06 AM »
i dont think it would be air or it would sound like a wave or surge  did you take the front cover off to see if the paint is rubbed off behind the fine tube
tulenutn2o
  • OWF Brand: HeatSource1
  • OWF Model: Earth Energy 190
Re: Baseboard noise
« Reply #5 on: November 16, 2011, 07:05:43 PM »
Boogey man! ;D ::)
Re: Baseboard noise
« Reply #6 on: November 16, 2011, 10:01:17 PM »
I have heard air make some weird noises.
beeman
Re: Baseboard noise
« Reply #7 on: November 27, 2011, 08:24:33 AM »
roger have you gotten it stratten out
Re: Baseboard noise
« Reply #8 on: November 28, 2011, 12:52:26 PM »
beeman;  Not yet.  I haven't had time to get back to it but as soon as time gets manageable again, I plan to purge that zone and see what happens.  I'll post back with the results.  Thanks for asking.  Roger
rhugg
  • OWF Brand: Legend
  • OWF Model: 6180
Re: Baseboard noise
« Reply #9 on: November 28, 2011, 01:13:19 PM »
If it is normal expansion then you'd also expect to hear it during the contraction cycle.  But maybe not since the contraction is slower.  All those new baseboards with a copper pipe surrounded by aluminum fins depend on something to support the fins.  Usually between the fins and the support is a plastic absorber.
Otherwise, it doesn't hurt to check for air.  If that doesn't work I'd buy some foam, roll it tight and stick it ...... in your ears. >:D
Re: Baseboard noise
« Reply #10 on: November 29, 2011, 11:32:31 AM »
rhugg;  I hear the expansion when the thermostat calls for heat and the water is flowing.  I hear the contraction when it no longer needs the water flow.  But, what I hear is a constant noise the entire time it is heating that zone, not just a short burst of noise.
beeman
Re: Baseboard noise
« Reply #11 on: November 29, 2011, 05:49:19 PM »
is it tite to both walls
Re: Baseboard noise
« Reply #12 on: November 30, 2011, 08:01:17 AM »
beeman;  Looked over the baseboard units last evening and nothing appears to be rubbing anywhere.  So, I may have time this weekend to purge the system.  Hopefully that will rectify the problem.  I'll report back when and if I have time this weekend.
Thanks for your help.
Roger
beeman
Re: Baseboard noise
« Reply #13 on: December 04, 2011, 10:14:17 AM »
could it be the finn sliding on the hangers i think they sell a plastic pice to go there .  mite try old milk jug cut little pice to go over the hanger but dont leave the jug pice permant just for test run see if it makes diffrence
Re: Baseboard noise
« Reply #14 on: December 20, 2011, 09:33:56 PM »
water hammer?
