Pages: 1 [2] 3
Author Topic: Best chain sharpener?  (Read 36852 times)
chuck_brown14
  • OWF Brand: Wood Boiler LLC
  • OWF Model: Extreme
  • 419-553-6507
Re: Best chain sharpener?
« Reply #15 on: January 23, 2012, 06:24:16 PM »
i hand sharpen also unless i hit concreate or metel in tree. then grinder
Same here
Chuck
bajonesy77
  • OWF Brand: Prosteel
  • OWF Model: 200
« Reply #16 on: January 25, 2012, 10:56:52 PM »
I use a hand file and elbow grease, till I run out of elbow grease then a dremel with a grinder.
Brave 22 ton splitter
Stihl 440 magnum 20" bar
Stihl 390 20" bar
chadley
  • OWF Brand: none-looking
« Reply #17 on: February 04, 2012, 09:06:30 PM »
I just tried sharpening my first chain yesterday.  Never done it before.  How many times should I run the file across the tooth?  Should I only run the file one way.  What I mean is; if I pus the file to sharpen should i pull it back along the same angle or should I take the file off the tooth and bring it back to push it forward again?  Hope my questioin makes sense.
gspren
  • OWF Model: ML 30
« Reply #18 on: February 05, 2012, 06:10:50 AM »
Never back drag the file! The file should only touch the metal while taking a cut, letting it touch while pulling back will dull the file. Keep practising, it would be good if you could watch someone experienced file a chain, its not that hard.
Portage & Main ML30
Stihl 261
Stihl 044 (15 years old)
Stihl 041 (30 years old)
Yamaha Kodiak 4 Wheeler
John Deere 2355 4x4 loader tractor
70 acres (23 wooded)
trz
« Reply #19 on: February 11, 2012, 01:42:49 PM »
any tips for hand file sharpening?    Gauge or no gauge ?   I always seem to get a good bite going one direction then when i do the teeth on the other side seems like the file always wants to skim across without biting.   any help would be............well.... helpful.
tree climber
  • OWF Brand: leaky 165 shaver
  • OWF Model: 165
« Reply #20 on: February 11, 2012, 03:26:52 PM »
i like to put the saw in a bench vice to hold it so you can get more down presureon the file
tbone
  • OWF Brand: Heatmor
« Reply #21 on: February 23, 2012, 09:08:14 AM »
I purchased a dremel with the sharpening kit last week and it works very well.  I have found at low rpms you can get the same results as hand filing in a fraction of the time...very sharp chains without removing a lot of metal or overheating your chain.
Stihl pro 360
Honda 27 ton splitter
Ford 350 with hoist
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« Reply #22 on: September 26, 2012, 05:46:41 PM »
TimberTuff bench grinder.
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
« Reply #23 on: September 26, 2012, 07:32:42 PM »
Best chain sharpener is the hand file...hands down..
« Reply #24 on: September 27, 2012, 08:45:54 PM »
best chain sharpener for my saws...anyone but me..lol
rross
« Reply #25 on: November 25, 2012, 01:25:58 PM »
A good Dremel and diamond stone.  Does not overheat the chain like regular stones.
garz
  • OWF Brand: Central
  • OWF Model: CL-17
« Reply #26 on: November 26, 2012, 09:20:25 AM »
I looked at the sharpener from Harbor Freight & it looked like a cheap collection of plastic parts.  But, they had it on sale & I had a coupon so, I figured “What the hell, for $20 I’ll take a shot”.  That was 3 years & a couple of hundred sharpenings ago. Now I keep 4 saws of my own going & do chains for 4 or 5 of my neighbors. Got to be the best 20 bucks I ever spent. Out in the woods, I can easily flip a spare sharp chain on the saw in the time it would have taken to hand file the dull chain.
Central CL-17 that's old enough to vote
Stihl MS362, 028, 192T
Husky 286XP
Swisher 30T splitter
IH 235 diesel tractor
Paris, IL
ford tech
  • OWF Brand: hardy
  • OWF Model: h2 2003 - 2014 CB 6048
« Reply #27 on: November 26, 2012, 02:30:29 PM »
I USE A BENCH MOUNTED SHARPENER FROM STIHL - THAT USES A ROUND HAND FILE WORKS GREAT
stihl ms460
stihl 36pro
farmall h
HARDY H2 heating 1600sqft home and 42x42 insulated MORTON shop floor heat - installing a cb 6048
lasor1
  • OWF Brand: Heatmaster ss
  • OWF Model: Heatmaster mf 5000
« Reply #28 on: December 02, 2012, 05:55:40 AM »
I suggest learning hand file. Because if you use grinder style sharpeners u will always use one because it does heat the chain up no matter how little you use it and makes it hard to file chains and if you cut a lot you better keep a file with you in the field. With a grinder u cannot. Use unless u have power so I suggest a hand file or get you several chains to take with you if you go the grinder route. Which it's always a good ideal to have an extra chain and a backup saw with you anyways.
netwerx-r-us
  • OWF Model: Hoss 400HE
    • Netwerx-R-Us
« Reply #29 on: January 20, 2013, 08:53:26 AM »
Amen and a second , i can do almost anything but hand sharpening a saw and laying brick are 2 things best  left to others
Netwerx-R-Us
http://netwerx-r-us.com
Echo 440
Honda Rancher 400
Kubota ZD326
Pages: 1 [2] 3
