Author Topic: Homemade door insulation  (Read 8616 times)
countryguy
« on: December 05, 2011, 07:34:10 PM »
I have finally started my build after 2 yrs. of studying,I'm at the point of building my door any suggestions of what to insulate it with. I am not going to use water to much of a pain in the a** this late in the year just need to get it going. Any thoughts on filling with sand maybe? Also what model number of honeywell aquastat do I need to run the fan?Any input appreciated!!!
Re: Homemade door insulation
« Reply #1 on: December 05, 2011, 07:39:34 PM »
Vermiculite is what a lot of companies use, hard to beat it.
« Reply #2 on: December 05, 2011, 08:03:58 PM »
country, there will be many things you can likely use. i built my door freame out of 4x4 angle and used fire brick sitting on the ledge of the angle and a piece of wire mesh tacked over top to keep it in place. after a year or so the fine ashe filled in the cracks between the bricks. with a raging fire it does get hot enough that you cold pu tyour hand on it but you dont want to. i guess that means  it is not as good as some other stuff but it sure isnt as hot as the inside!
newmod
  • OWF Brand: HOMEMADE
« Reply #3 on: December 06, 2011, 07:50:51 AM »
I had a hard time finding insulation also.  I ended up using ROCKWOOL,  I think the temp range it can be used for is up around 1000 deg C.  Hope it works.  I am firing mine up tomorrow.
beeman
  • OWF Brand: homemade
« Reply #4 on: December 06, 2011, 05:26:47 PM »
i used insulation r30 unfaced i guss doing good i can place my bear hand on the door worm not hot
« Reply #5 on: December 06, 2011, 05:29:26 PM »
sounds like  you found the right stuff!
jackel440
« Reply #6 on: December 07, 2011, 01:12:56 PM »
i used K-wool insulating blanket material in my doors.Same stuff used in heat treating furnaces,industry,etc.....
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
