Author Topic: trouble maintaining temp  (Read 12106 times)
Re: trouble maintaining temp
« Reply #15 on: December 19, 2011, 01:03:56 PM »
your stove you sau is rated at 500,000 btu..where the manufactures get that i don't really know. perhaps that is at the outlet of the stove and with a full load of good dry wood. if youwere to get the max from yoru stove i would make a guess that it would need to be kept very full of fuel and as it burnt you wouldhave to add more to keep the btu output high. also to deliver that amount of heat to yoru pool you would need to move about 50 gpm at 180 degrees (not likely going to happen) but the pump upgrade you are going for will help (and maybe a smaller heat exchanger at the pool)
if you moved teh water faster to the pool and used a smaller exchanger that would restrict how many btu were going into the pool it owuldhave to deliver this amount of btu for a longer period of time but the water moving faster and not giving up the maximum amount of btu should give yoru stove time to recover to above the 150 degree mark
lets say you need that 500,000 to raise the pool to the desired temp. and it runs for 1 hour like that..and yor return temps were 130 and your furnae couldnt recover...now lets say you move the water faster and use a smaller exchanger at the pool. you still deliver the 500,000 but instead of in 1 hour you take 3 or 4..the return temp of the water will be much higher (lets say 150) and now your stove can recover...it will run lnger but will be able to produce enough btu to keep you above the 150 and not shut down your heat supply to the house.
« Reply #16 on: December 19, 2011, 01:30:41 PM »
No need to get a small heat exchanger, just put a bypass on it and adjust the valves to allow the right amount of water through it. It will have the same effect as putting a smaller heat exchanger on it.
« Reply #17 on: December 19, 2011, 01:49:11 PM »
that will do it also i was jsut using the smaller exchanger so as to demostrate delivering less btu to the pool. as always RSI your explanations are right on
martyinmi
« Reply #18 on: December 19, 2011, 02:59:36 PM »
That would be simple- a couple of tee's and a few valves and you are in.
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
