Author Topic: Making my boiler more efficient -- question  (Read 21683 times)
Re: Making my boiler more efficient -- question
« Reply #15 on: December 22, 2011, 10:34:29 AM »
My system uses the following tubing and set up.
 http://www.trueleaf.net/pdf/Benchwarmer-Bro-2005.pdf
The fin type you have photos of are very hard to get and expensive. I have seen them in older boiler type greenhouses. Usually a few feet under the tables.
I have a lot of them that were taken out of an old greenhouse. I thought they would sell easy but not much interest so far.
MTJAG
  • OWF Model: CL5036
« Reply #16 on: December 22, 2011, 01:27:40 PM »
I might have an interest.  How long are they and can I pipe them together end-to-end?  Where are they located and how could we ship them?
« Reply #17 on: December 22, 2011, 01:40:29 PM »
There are a few different lengths from about 8' to 12' long. I can cut them down and re-thread them but might be better just using radiator hose. They were about half connected together with has and half iron pipe when  they were removed. They are 1-1/4" pipe
I am in Wisconsin. They would probably need to be shipped by LTL freight.
The simplest way to control the heat would probably be to keep a pump running continuous and use a mixing valve to control the water temperature. Once you get the water temperature set right it will keep the air temp pretty constant.
