Author Topic: Installing in a Doublewide Mobile home??  (Read 28252 times)
hddmax66
Re: Installing in a Doublewide Mobile home??
« Reply #15 on: January 23, 2012, 05:22:12 PM »
i didnt have the space either but i took out a lil wall and some useless cabnets on the left is my washer and dryer and on the right was a pantry like you prolly have. Needless to say its gone now. I really wish i had a basement!
@ RSI i think i needed like 19.5 x 19.25 somewhere close to that. I searched everywhere and couldnt find one. i found great deals at www.freeheat4u.com and is in driving distance for me to pick up! so i had to get the 19x20 which is actually 19.25x22. the next one smaller was 18x18 which is actually 18.5x20. Go big or go home is my motto!
« Last Edit: January 23, 2012, 05:24:39 PM by hddmax66 »
« Reply #16 on: January 23, 2012, 05:31:15 PM »
Yeah that is a hard size to find. There are some that measure 18x19 or 19x20 but would have cost more. You probably went with the best size.
Daped01
« Reply #17 on: January 24, 2012, 10:27:09 AM »
Ok, thank you very much.  I received alot of information from alot of people I consider "credible" from reading this site over the year.  I've been lurking here for a year or so and am so thankful for all the information i've learned from just reading.
« Reply #18 on: January 24, 2012, 10:50:58 PM »
Generally speaking doublewides are down draft furnaces with an A coil on top. If you can raise the A coil and slide the flat coil in between it works well. One thing I would point out is to look at both the size of the base of the A coil and the opening on top of the furnace where the air goes from the A coil into the fan. Often this opening is around a 16x18 or 16x16 opening. If you install a coil larger than the opening you really don't gain anything because the overhanging part will not be used. I almost always use a 16x16 coil ( with flanges 16.25x18).
 One problem to watch out for when installing this way. If the A/C unit is low on freon or if the cover of the furnace is left off the coil can freeze up. I had one case where the coil froze and busted twice. The way I fixed the problem was by installing a sensor on the wire from the y terminal to the outside unit so that whenever the coil dropped below 38F the compressor would stop. This seemed to solve the problem.
Daped01
« Reply #19 on: January 25, 2012, 12:09:17 PM »
great information yoderheating.  Thank you very much
« Reply #20 on: January 25, 2012, 02:16:54 PM »
What did you use for the sensor to shut off the AC? That probably wouldn't be a bad idea to put in every system if it is cheap enough.
« Reply #21 on: January 25, 2012, 07:16:03 PM »
 I can't even remember the brand I used. I just went into my HVAC supplier and told them what I wanted. It was very simple little device that clipped onto the line and had two wires out of it. Simply had to splice the yellow wire through it and was done. I want to say it cost less than $20. I am thinking about using them on all coils that are located directly beside the A coil where it has any chance at freezing.
