Author Topic: Stacked plate HX sizing help needed  (Read 13719 times)
Re: Stacked plate HX sizing help needed
« Reply #15 on: January 28, 2012, 10:23:47 AM »
Grateful guy your underground line shouldn't melt snow I don't care if it's laying on top of the ground..  I've installed in snow and let it lay all winter and not melt the snow using triple wrap.
One of the biggest mistakes people assume is deeper means better Insulated....  Wrong.        When your heat escapes your insulation, it's gone, it doesn't matter if you lose it to the ground, the air, groundwater. Whatever, once it's gone it's gone.
I have even seen people bury line 5-6ftdeep and brag it's not mounting snow now, little do they know there just heating more dirt .
If there is no ground water down the 5-6 feet there will be a little less heat loss there. Heat loss happens from temperature difference. The higher the temperature difference the higher the heat loss. If it is 50 degrees down 5' and 0 degrees at 12" you will definitely get less heat loss at 5'. If you have ground water at 5' you will lose more heat then even if it is warmer because the water will conduct heat away.
« Reply #16 on: January 28, 2012, 10:34:28 AM »
Yea that's true rsi, I've just never seen anywhere in my area where the water table doesn't rise up to within at least 3 feet at times.  I'm sure other areas are different.
In my back yard on the edge of the creek the soil is about 2 feet deep before solid rock, 80 feet back to my house it's 4 foot down to rock.  Water doesn't have anywhere to go lol
« Reply #17 on: January 28, 2012, 10:40:18 AM »
yeah, if you have a high water table you want to keep above it.
Around here you could go down 30' and not get anywhere near the water table in a lot of places
fireboss
« Reply #18 on: January 28, 2012, 03:15:57 PM »
a 40 plate ex cost me like 600 i think 2yrs ago, dont think i need it but its  there so iam leaving it for now!again knowing what i know now i would not have put it in
