Author Topic: 1 month complete: info, observations, and tips  (Read 5337 times)
woodfuel
  • OWF Model: cl5036
« on: January 27, 2012, 08:07:50 PM »
Info: 2250sq ft ranch, 2250 sq ft partially exposed basement. OWB is hooked up 12/27/11 to forced air propane furnace, 800sq ft basement in floor heating, and propane water heater. Propane is only used for stove. Grundfos pump on owb, taco actuator for in floor, side arm exchanger for water heater
Observation: OWB is awesome! Basement t-stat is set at 65, but i haven't witnessed the temp below 66 and as high as 69 with the taco actuator never calling for more radiant heat.  We always have hot water, so water heater never kicks in for propane usage. T- stat upstairs is set at 68, and during the day has went up to 73 with the sun out. If the temp is above 25 and sunny outside, blower on propane furnace doesn't kick in. This has been a mild winter so far here in WI, so i have been able to just feed it pallet scraps and scrap building materials most of the time. I have used mixed wood overnight if the temp is supposed to drop under 20 just to make sure the fire doesn't go out.  Just saw my first savings when the propane truck pulled in, and then pulled right out.
Tips: Wear safety glasses always, use a light to attach to hat or band around head and hook up front light to go on when damper opens (thanks for the tip, ridgekid!)  -matt
[attachment deleted by admin]
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
Re: 1 month complete: info, observations, and tips
« Reply #1 on: January 28, 2012, 05:41:02 AM »
I wish you the best with you 5036 we had our's going since early march of 2009 we get all of the heat we want and super hot water. :thumbup:
New Holland TC30 tractor
powerdiver6000@aol.com
woodfuel
  • OWF Model: cl5036
« Reply #2 on: January 28, 2012, 09:58:26 AM »
Thanks, pwdiver.
big a
  • OWF Model: 4030
« Reply #3 on: January 29, 2012, 09:25:07 PM »
Had my 4030 about a month an a half. Heating water and a 2000 sq ft home. Home is double insulated. Feed stove about once a day and forget it.love my new cb.
« Reply #4 on: January 30, 2012, 07:50:40 AM »
Welcome to the site Big a and congrats.
