Pages: 1 [2] 3
Author Topic: My owb running smoke free (video)  (Read 33349 times)
Re: My owb running smoke free (video)
« Reply #15 on: February 14, 2012, 06:30:32 PM »
Yea my cousins looks like a locomotive with coal
I think part of the smoke issue is having the stack exit directly out the top with no time for burning some of the gases
I think you are right Scott and that is not the best design but like AirForce said they work.
No doubt about that
johnybcold
  • OWF Model: Classic E1400
« Reply #16 on: February 15, 2012, 11:01:59 AM »
Your burning coal in it?
old truck
old craftsman chain saw
Polaris Sportsman 500HO
« Reply #17 on: February 15, 2012, 02:27:56 PM »
Yes, of course..   Questions?
AirForcePOL
  • OWF Model: G400
« Reply #18 on: February 16, 2012, 07:34:21 AM »
Does it look about like this? lol
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
MD20/20
  • OWF Brand: Nature's Comfort
  • OWF Model: 325G
« Reply #19 on: February 16, 2012, 07:54:28 AM »
what is that?
Central MD
AirForcePOL
  • OWF Model: G400
« Reply #20 on: February 16, 2012, 08:17:32 AM »
That's my Hardy smoking like crazy.
Athens, Illinois
Stihl MS 290
« Reply #21 on: February 16, 2012, 08:27:13 AM »
Looks like some I've seen.  I've seen flames shooting 4 feet up out of the stack
AirForcePOL
  • OWF Model: G400
« Reply #22 on: February 16, 2012, 08:38:32 AM »
Yeah, mine will shoot flames every once in a while but usually only when I load it full with smaller split pieces.  It looks pretty cool too!  :thumbup:
Athens, Illinois
Stihl MS 290
« Reply #23 on: February 16, 2012, 12:59:59 PM »
There is no secondary burn chamber at all? if you look down the chimney you can see the wood in there?
AirForcePOL
  • OWF Model: G400
« Reply #24 on: February 16, 2012, 01:10:03 PM »
Yup, the chimney doesn't stick down into the firebox either.  Just a hole at the top.
Athens, Illinois
Stihl MS 290
« Reply #25 on: February 16, 2012, 01:17:49 PM »
Are you interested in doing an experiment on it? If there is no extra space inside to put a plate you could try making an external secondary burn chamber. Just to see if would work you could use an old steel barrel. It would probably work best to put it on it's side. Cut a hole at one end for the chimney and one on the opposite side and end for the smoke to exit. I would also put a small fan on it to blow air in right where the smoke enters and is the hottest.
If it works something could be made up that was water jacketed to collect the heat it generates.
« Reply #26 on: February 16, 2012, 01:18:33 PM »
Yea RSI, there is just a round hole in the very top of the firebox
AirForcePOL
  • OWF Model: G400
« Reply #27 on: February 16, 2012, 01:45:16 PM »
Interesting.... I have a buddy that has an empty keg.  Do you think it would melt?
Athens, Illinois
Stihl MS 290
« Reply #28 on: February 16, 2012, 01:48:34 PM »
Is it aluminum? The fire in the secondary chamber could get hot enough to ignite aluminum. You need steel.
AirForcePOL
  • OWF Model: G400
« Reply #29 on: February 16, 2012, 02:27:32 PM »
I'm assuming it is aluminum.  I doubt I would ever have the time to tinker with it but it sounds like a good idea.
Athens, Illinois
Stihl MS 290
Pages: 1 [2] 3
