Author Topic: water directon  (Read 15107 times)
trz
water directon
« on: February 11, 2012, 11:50:43 AM »
what would happen if you had your water running backwards through the furnace and lines?
Re: water directon
« Reply #1 on: February 11, 2012, 11:56:44 AM »
What do you mean?  The pump has to be in the loop somewhere pulling water off the stove, you can switch the supply and return but, most stoves pull from the bottom to increase circulation and even heat in the water jacket
trz
Re: water directon
« Reply #2 on: February 11, 2012, 12:54:07 PM »
I'm confused!   I'm thinking maybe i have the water line that's supposed to be going TO the house hooked up to the RETURN pipe on the stove.
  I don't know if any of this makes sense to anyone here but, it seems htat the water temp when i read it on what I'm thinking is the return line in my house it reads hotter that the line that i think is the incoming water.
   I've had all the plumbing done in the house and then at one point I moved the furnace. what if i were to have hooked up the incoming and outgoing lines backwards when i hooked it back up?
Re: water directon
« Reply #3 on: February 11, 2012, 12:57:58 PM »
Where is your pump?
jerkash
  • OWF Brand: Legend
Re: water directon
« Reply #4 on: February 11, 2012, 01:09:33 PM »
As per my directions and the mfg, my water comes from the top and return goes in the bottom.  The water is hotter at the top and pushing it in at the bottom mixes it up better.
trz
Re: water directon
« Reply #5 on: February 11, 2012, 01:21:26 PM »
Where is your pump?
on the back of the furnace.   (Hawken 1000)   Disconnected both water lines below the pump. What if i inadvertanlly hooked them up backwards when i hooked them back up?
is there some way to check which way the water is actually flowing ?
« Last Edit: February 11, 2012, 01:23:25 PM by trz »
Re: water directon
« Reply #6 on: February 11, 2012, 01:38:40 PM »
Just look at which line the pump is on and which way it's flowing
Re: water directon
« Reply #7 on: February 11, 2012, 01:39:56 PM »
It can't push water into the stove and expect it to find it's way out
trz
Re: water directon
« Reply #8 on: February 11, 2012, 01:55:02 PM »
that makes sense!
But, know  how do you explain my return water being Hotter than the water going To the house.
Re: water directon
« Reply #9 on: February 11, 2012, 02:19:29 PM »
i twould be possable to hook your pump to the return line...you would still be pushing water to the house but through the wrong pipe. if they were not color coded perhaps you should have marked them and you would know for sure?
trz
Re: water directon
« Reply #10 on: February 11, 2012, 02:40:34 PM »
Thanks, but it's too late for 'Perhaps you should have'. That doesn't help me a bit!
  Now, I'm Quite sure i didn't hook it up wrong,,as i did mark them when i took them off but,  when i started checking temps. and the return line seems to be hotter than the incoming water it made me start thinking 'what if'  .  But, i still can't figure how my return water  can read hotter than the incomig water.
    Now, the whole reason this started was because i'm burning ridiculous amounts of wood and last summer i added 20" of insl. and it's been a mild winter and my wood consumption hasn't gone down so I'm trying to figure out what the prob. is.
« Last Edit: February 11, 2012, 02:46:49 PM by trz »
Re: water directon
« Reply #11 on: February 11, 2012, 03:11:06 PM »
i guess if yoru pump is at teh stove you could shut it off..take the lines apart in the house. put them in a bucket..have someone jog the pump on for 10 or 15 seconds and see what pipe the water is coming out of?
what do you consider ridiculous amounts of wood?
do you have a gasser or a non gasser?
do you use more wood now than you did when you first hooked up?
one thing that can lead to more wood usage in your underground lines getting wet  or  yoru jacket around them failing?
Re: water directon
« Reply #12 on: February 11, 2012, 07:06:32 PM »
How r u checking the temps?
Re: water directon
« Reply #13 on: February 11, 2012, 09:43:57 PM »
Are you saying you got the pipes mixed up at the boiler and not sure which is which? The pump will have an arrow on it so you can see if that is the right way.
What do you have for valves? If you have enough you can shut them and open a valve in the house and find out that way.
Another way might be to try looking for marking on the pipe. Some brands have a mark every 5 feet so if you are lucky you might find one on at least each pipe and possibly figure out from that.
dwneast77
    • HeatherWood Gardens
Re: water directon
« Reply #14 on: February 23, 2012, 07:32:46 PM »
On my Thermopex from CB, both lines are red but one has a black stripe.  I would think there would be some type of marking to let you know.
Eastern Maine (near Calais)
Central Boiler E-2300
Wood Doctor HE10000
Stihl 290 Farmboss
Craftsman 27 ton Splitter
JD 870 Tractor
