Pages: [1] 2 3
Author Topic: insulated pex  (Read 29969 times)
d conover
  • OWF Model: H4
insulated pex
« on: March 07, 2012, 07:36:47 AM »
Has anyone used ozarkbiomassfurnace.com's 4 line insulated pex?  They make it themselves here in Missouri.
Talked to a super nice lady at the factory yesterday.
they are also this place.
www.outdoorwoodfurnaceparts.com
« Last Edit: March 07, 2012, 07:46:46 AM by hd5 »
Southeast Missouri
Hardy H4
044 Stihl
038 Stihl
5100s Dolmar
55R husqvarna
CS301 Echo
Re: insulated pex
« Reply #1 on: March 07, 2012, 04:21:31 PM »
I can't find it listed on either of your links. What type of insulation do they use?
Re: insulated pex
« Reply #2 on: March 07, 2012, 04:47:07 PM »
Most 4 line I've seen looks pretty crappy
Re: insulated pex
« Reply #3 on: March 07, 2012, 04:48:44 PM »
What do you think of this?
Re: insulated pex
« Reply #4 on: March 07, 2012, 04:49:39 PM »
By far the best I've ever seen
slosh250
Re: insulated pex
« Reply #5 on: March 07, 2012, 05:17:00 PM »
Whats the price on it if you dont mind, i am also in Missuouri
swede
  • OWF Brand: shaver 165
Re: insulated pex
« Reply #6 on: March 07, 2012, 06:18:36 PM »
Looks like Badger 5 wrap.  I paid 8.19 per foot shipped for the 4 line.
the smoke don't mean its broke
Re: insulated pex
« Reply #7 on: March 07, 2012, 06:21:54 PM »
How many feet did you get?
martyinmi
Re: insulated pex
« Reply #8 on: March 07, 2012, 06:55:22 PM »
I saw Logstor true 1" closed cell at the farm show that looks a lot like Thermo-Pex, only bigger. That stuff looks incredible! Over 13$/ft.
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
newmanab
  • OWF Brand: Central boiler
  • OWF Model: CB6048
Re: insulated pex
« Reply #9 on: March 07, 2012, 07:51:06 PM »
I put in 140ish feet of logstor. $10.50 ft  :bash: but i don't regret it.  Very little heat loss.
When house isn't calling for heat i have about a 3 degree heat loss from supply to return @ woodburner from the following:
140 feet of logstor= 280 ft
60 feet of 1" pex in house
Side arm dhw
Water to air H.E.
All being pushed by taco 007 which will be switch out by something more efficient when it dies.
tbone
  • OWF Brand: Heatmor
Re: insulated pex
« Reply #10 on: March 08, 2012, 06:12:44 AM »
I am guessing you guys don't like the foam filled?
Stihl pro 360
Honda 27 ton splitter
Ford 350 with hoist
swede
Re: insulated pex
« Reply #11 on: March 08, 2012, 07:38:20 AM »
I purchased 90 ft. of line.  Run is 80 ft. and the manufacturer suggested adding 5 ft. extra for each end of the run.  Spendy enough but it is an excellent product.
Re: insulated pex
« Reply #12 on: March 08, 2012, 08:38:40 AM »
I'm not a huge fan.  Badger claims there 5wrap retains even better.
I get interested in it from time to time, had a salesman spend 3 hours workin me over to start using logstor, the numbers he showed me werent as good as the 5 wrap and my cost was over double the 5 wrap.
The real success story with foam filled is the marketing machine central boiler, they can make anything sound great.  However both pipe can fail if it gets a leak, that's why proper installation to me is wayyyyy more important than choosing between 2 quality lines.   Someone said if the logstor gets a hole on it you can't hardly get it out of the ditch because it soaks up so much water
newmanab
  • OWF Model: CB6048
Re: insulated pex
« Reply #13 on: March 08, 2012, 01:32:27 PM »
I don't want to start a pi$$ match , logostor is made from closed cell insulation.  Closed cell insulation won't soak up water.   I actually took some of the insulation when i was trimming mine and put in a bucket of water because i was curious about this also. No weight change.
All that set aside we are all trying to accomplish the same thing minimal heat loss.
« Last Edit: March 08, 2012, 01:34:12 PM by newmanab »
Re: insulated pex
« Reply #14 on: March 08, 2012, 01:51:34 PM »
How long did you have it in the water? Several different people have told me that it does soak up water. The only explanation I can think of is it gets hairline cracks in the foam from being rolled and unrolled and water channels through them.
Pages: [1] 2 3
