Author Topic: While cleaning  (Read 6958 times)
While cleaning
« on: May 10, 2012, 03:29:07 AM »
While cleaning my OWB for the summertime shutdown, I noticed a crack had developed on the refractory on the floor of the firebox.  When I removed them, those weren't cracks, they were fractures.  Both segments of the refractory came out in pieces.  I know I'll have to replace them.  This OWB is a Central boiler e-classic 1400, new and put online in Oct. 2011.  I have a couple of questions;  1)  What would have caused this?  2)  Can I expect to have to replace them every year?  3)  Any idea how much the replacement cost is for them?
Thanks,
Roger
HandyMark
Re: While cleaning
« Reply #1 on: May 10, 2012, 08:42:16 PM »
Check out this thread. I am not following it closely but it appear to be a similar issue. http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=2030.0;topicseen
johnybcold
  • OWF Model: Classic E1400
Re: While cleaning
« Reply #2 on: May 12, 2012, 06:52:36 PM »
This was my first year with a 1400 too , and I have 1 large crack in he same place it goes all the way through to the ash chamber, I am hoping it is not hard to replace it looks like I can just remove it and drop a new one in.
old truck
old craftsman chain saw
Polaris Sportsman 500HO
boilerman
Re: While cleaning
« Reply #3 on: May 12, 2012, 09:07:41 PM »
If there is only one or two cracks and the brick slots still hold the grate rods, I would keep using unless it crumbled and can't hold rods. I wouldn't buy a replacement until then. I believe the owners manual mentions this.
Re: While cleaning
« Reply #4 on: May 13, 2012, 04:38:16 AM »
After I completed the thorough cleaning I put back the pieces of refractory that were broke and they mated together nicely.  I think I'll leave them alone unit they become an issue.  Does anyone know if there is a compound available to "glue" the piece together that will hold up to the heat?  If not, I'll try it without it and see what happens.  Thanks for you help.  Roger
Re: While cleaning
« Reply #5 on: May 13, 2012, 08:15:09 AM »
Re: While cleaning
« Reply #6 on: May 13, 2012, 11:08:20 AM »
Something like this might work. http://www.quikrete.com/productlines/FireplaceMortar.asp
RSI - Thanks for the link.  The next time I'm at Home Depot I'll have a look around.
Roger
