Author Topic: Pressure Guages  (Read 9022 times)
jedc43
  • OWF Model: CL-6048
Pressure Guages
« on: October 01, 2012, 08:19:14 PM »
hi all,
  new to the forum...we recently bought a house in Mass and I am now a owner of a Central Boiler cl-6048.Does anyone know what the pressure guage reading should be from the heat exchanger to the OWB....and the pressure from the Heat exchanger  to the oil burner.I just drained my OWB and refilled with the proper chemicals and changed all the filters....I think I am familiar with just about everything but the amount of pressure generated by the circulator pump....I realize that it might be differant from stove to stove but I am just looking for a ballpark figure on what to look for before I start burning in a couple of weeks.    ...My OWB is about 150 feet domnhill from my home...my home is about 3400 Sqft with radiant floor heat and baseboard heat....all forced Hot water  wich also heats my Domestic hot water......
        Thanks ,
        Marc
muffin
Re: Pressure Guages
« Reply #1 on: October 02, 2012, 12:17:29 PM »
Should be 0.  It is an unpressurized system.  I suppose you might get a couple psi from elevation????
Re: Pressure Guages
« Reply #2 on: October 02, 2012, 03:07:01 PM »
You get about 1 PSI for every 2.3' of elevation. The amount the pump raises it beyond that will depend on how much restriction you have.
jedc43
Re: Pressure Guages
« Reply #3 on: October 03, 2012, 05:48:22 PM »
So if my boiler is around 20 feet below my house in elevation...the pressure guage should be around 10 PSI
Re: Pressure Guages
« Reply #4 on: October 03, 2012, 05:55:11 PM »
I'm curious as to why you are concerned with pressures?  It's an open system and the only psi produced is from elevation and restrictions
Are you worried something is gonna blow up, or are you sizing pumps?
Re: Pressure Guages
« Reply #5 on: October 03, 2012, 06:25:23 PM »
If your boiler is lower than the house (and the pressure gauge is in the house) it will actually be a negative pressure if the pump is off and there are no leaks that could let air in. The pressure with the pump on would entirely depend on restriction after the gauge and the pump size.
jedc43
Re: Pressure Guages
« Reply #6 on: October 04, 2012, 05:25:41 PM »
...no..no worries about explosions....just curious...never had this type of stove before and I am trying to monitor pressure so I know when to change filters
