Author Topic: Homemade insulated PEX  (Read 28676 times)
Re: Homemade insulated PEX
« Reply #15 on: October 24, 2012, 04:56:42 PM »
im at the other side of you...near sarnia at the border. there are a couple of guys near me that sell the  stuff. i bought mine 2 years ago so i don't know if price is up or down now?
MrDan27611
  • OWF Model: ML42
« Reply #16 on: October 30, 2012, 09:43:53 AM »
I reinsulated my underground pipes after 30 years in the ground. I made a video of what we did.
Redoing the underground pipes on my wood boiler
I'm getting less than a degree drop over the span and so far it's working just fine.
Don't go around saying the world owes you a living. The world owes you nothing. It was here first.
Mark Twain
AirForcePOL
  • OWF Model: G400
« Reply #17 on: October 30, 2012, 10:17:56 AM »
good video MrDan.  You definitely have enough insulation on there.  I would be worried about that pipe being split all the way down though.  Even though it is on the bottom I would think that water would still find its way in there.  But hey, if it works then it's all good!
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
MrDan27611
  • OWF Model: ML42
« Reply #18 on: October 30, 2012, 10:58:47 AM »
I was worried about that too. In fact I still am. I can always pull it up and redo it with commercial PEX later if need be. At the time this was the best option I had, especially since I didn't want to cut and replace the pipes. Splitting the corrugated was the only way.
This weekend I spent half the weekend getting inside my in-house 500 gallon water tank/heat exchanger setup. After 30 years it had started leaking. 5 hours of grinding/cutting, and 2 hours of welding and it looks like it's holding water. A 14" crack had developed in the bottom right on the seam of the tank. Kinda hard to call it a manufacturing defect after 30 years but it sure looked like the weld wasn't done very well. Anyway, I'm not scared of some weekend work so if I ever have to replace it, no big deal, I figure I can get 5 years out of it easy even if it doesn't do exactly what I want. I'll hopefully have time to order the PEX in and have it ready to go should that day come.
Mark Twain
