Author Topic: 12v pump to replace current taco 0014-F1  (Read 10339 times)
ortiesdad
« on: November 04, 2012, 05:55:35 PM »
Hi Everybody...I'm a newbie to this message board and hopeful I can obtain some great information. I'd like to change my existing Central Boiler 6048 circulating pump to a 12v model that I can run simply on solar panels and deep cell batteries. Any suggestions or ideas is greatly appreciated.
Dave
Irwin, PA
jerkash
  • OWF Brand: Legend
Re: 12v pump to replace current taco 0014-F1
« Reply #1 on: November 04, 2012, 06:12:29 PM »
No more current than the pump uses, I would think it would take forever to get your money back on solar panels and batteries.  Just my thought.  I think it is great that you are wanting to try things like this.  Keep us posted if you do it!!
« Reply #2 on: November 04, 2012, 06:20:08 PM »
A lot of folks are totally off grid...  You'd be surprised how many
ortiesdad
« Reply #3 on: November 04, 2012, 06:25:31 PM »
Forgot to mention that I've already purchased the panels (2@35w and 2@70w) for $150 on Craigslist and have about five deep cycle batteries here that I've acquired over the past year. Just wanted to see if they even make a 12v pump.
Thanks for your replies!
Dave
« Last Edit: November 04, 2012, 06:28:59 PM by ortiesdad »
jbc
  • OWF Brand: ridgewood
  • OWF Model: 7500
« Reply #4 on: November 04, 2012, 07:22:46 PM »
Yea, it's called a 12v to 120volt adapter--cost about $15 on line for the adventurous folk' looking for
another way to "follow the yellow brick road".... :bash:
Guess I will never understand.....
« Reply #5 on: November 04, 2012, 08:50:16 PM »
If it were me I would get an old battery backup and open it up and connect the batteries you have to it and then run the pump through it. (if you want the pump to run when power is out)
Then just get a grid tie inverter and put connect the solar panels to that. It would be a lot more efficient.
ortiesdad
« Reply #6 on: December 11, 2012, 03:36:05 AM »
After lots of searching, I've come up with this Topsflo 10pv 12V solar powered hot water circulation pump.
http://www.ebay.com/itm/Topsflo-10PV-12V-Solar-Powered-Hot-Water-Circulation-Pump-/130815472772#vi-content
Any thoughts? I'd really like to take my Central Boiler completely off grid. The solar panels are sitting in my barn just waiting to go up.
Thanks for any ideas!
Dave
muffin
« Reply #7 on: December 11, 2012, 06:02:34 AM »
Not sure how the solar panels work.  Do they have any built in regulation?  What is there voltage range?  That pump has a huge input voltage range.  You could likely just tie the panels to a battery via a diode.  Looks like it only draws less than an amp.  Then as a safety, you could get a wall transformer and hook it in with a diode too just in case the batteries start getting low and there is no sun.  I would look for a 10V wall charger.
Is that pump big enough though.  1/2" pipe and only 2.6gpm seems pretty tiny.  Would not think you could get much heat out of that.
I would need the details on the solar panels to really design the system out.  I have never worked with them.
« Reply #8 on: December 11, 2012, 10:38:20 AM »
That pump is way too small.
You will be way better off just getting a 300w one of these and plugging it in an outlet http://www.ebay.com/itm/300W-500W-1000W-micro-grid-tie-inverter-for-solar-home-system-MPPT-function-/271049903292?pt=LH_DefaultDomain_0&var=&hash=item3f1bd54cbc
Will be way less headache than trying to use 12v pumps and batteries.
