Author Topic: add chimney height + or -?  (Read 18285 times)
walkerdogman85
  • OWF Model: H-4
« on: November 08, 2012, 07:09:56 PM »
I have a hardy and I am thinking about adding some height to my stack. Will it effect my burn time I am burning straight pine and only load it every 24 hours even longer the weather has been in the high 20s at night. I would just like to get the smoke a little higher but I do t want to have bracing. I also want to add a rain cap to keep water out. Please tell me the good bad and what you guys do and mabye post some pictures. Thank you
Michael West
Central Ohio
jerkash
  • OWF Brand: Legend
Re: add chimney height + or -?
« Reply #1 on: November 09, 2012, 03:27:45 AM »
I have a Legend.  It had a three foot pipe and I added another three foot pipe.  I did not see any difference in burn time and no extra bracing.
walkerdogman85
  • OWF Model: H-4
« Reply #2 on: November 09, 2012, 05:49:56 AM »
Ok I think the hardy dealer said something about adding up to five 3runs foot sections without bracing but I don't think I need to go that high
Michael West
Central Ohio
AirForcePOL
  • OWF Model: G400
« Reply #3 on: November 09, 2012, 07:19:15 AM »
It doesn't seem like that would even be able to stand up straight without any bracing if you ask me.
I have thought about adding one 3 ft section to my Hardy.  Are you just supposed to shove the new section down into the existing one?  I always wondered if it is recommended to put a clamp on there to hold it tight.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
walkerdogman85
  • OWF Model: H-4
« Reply #4 on: November 09, 2012, 01:09:38 PM »
The way he talked you just slide the two together but he wants 50 dollars a piece for 3 foot section of single wall
Michael West
Central Ohio
AirForcePOL
  • OWF Model: G400
« Reply #5 on: November 09, 2012, 01:22:23 PM »
that sounds about right from the Hardy dealer.  I think I paid $45.  I can't find it any cheaper anywhere else.
Athens, Illinois
Stihl MS 290
Jack72
  • OWF Model: E-1450 (11)
« Reply #6 on: November 09, 2012, 07:08:13 PM »
I know you dont have a CB but Menards has double wall stainless 3 foot sections for 36.00    thats what I used on mine not sure if that would work for Hardy???   Mine is a lot taller now 24 feet (Had a neighbor complain unfornately)    Now I need a lightning rod on it and a airplane light
 its only 8 foot in my profile pic           Jack
« Last Edit: November 09, 2012, 07:12:04 PM by Jack72 »
Chevy 2500 HD 13 Duramax
Stihl 046 036 009
Northern Tool 25 ton Splitter
bigdaddyjak
  • OWF Brand: Homemade
« Reply #7 on: November 09, 2012, 07:49:16 PM »
If it's outside, u don't need anything but cheap stove pipe, heck u can get 8"x5' pieces for around $8-$10 a section. I just use that aluminum tape the use on duct work for holding it together and sealing  it. But that's just me.
MattyNH
  • OWF Model: 7300E ; S-275
« Reply #8 on: November 10, 2012, 06:35:22 AM »
The problem with that is rots..Been there done that..Better off spending the money for the good pipe..
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
bigdaddyjak
« Reply #9 on: November 10, 2012, 08:31:56 AM »
I have to agree matty,
 only lasted me about 6 yrs on my aquatherm, but 3 sections making it an extra 6' and a $20 bill was not a big deal to me
dumbodog00
« Reply #10 on: November 10, 2012, 06:24:57 PM »
I have a Hardy H2 and had three sections of pipe screwed together for a while.  Eventually with the movement from the wind, the screws would not stay tight and it came down.
I have had as many as six together.  I used the thin angle iron type stuff with holes that is commonly used to hold up the garage door opener.  I ran it down both sides of the pipe and held that together with stainless radiator style clamps (but larger).  That worked pretty well until some super stong winds caused it to be damaged.  I should have used some type of "outriggers" but never did.
Now I have three sections clamped together and that is working well at this point.
walkerdogman85
  • OWF Model: H-4
« Reply #11 on: November 11, 2012, 03:37:26 AM »
What made you take the six down and leave three up? Did or does ot affect burn times.
Michael West
Central Ohio
dumbodog00
« Reply #12 on: November 12, 2012, 01:51:22 PM »
High winds mangled it some and I never put up anything to stabilize it, before or after.  I also didn't like the way it looked all that well.  I have a two story house and it did a good job at getting the smoke up and away.  Three vs. six was an easy compromise that looks okay and stands fine on its own.
Performance/burn times were not changed as far as I could tell.  I just hit it once in a while to knock the creosote down.
walkerdogman85
  • OWF Model: H-4
« Reply #13 on: November 12, 2012, 04:07:43 PM »
Ok I might add one or to hopefully it it help but I really have to get a rain cap
Michael West
Central Ohio
dumbodog00
« Reply #14 on: November 14, 2012, 09:28:03 AM »
The weak point is really that first section of pipe.  The way the H2 is designed, all the weight from above sits on one small area on the first, thin wall of pipe.  I wish it were designed differently so pipe could be added easier as with some of the other models on the market.
