Author Topic: air conditioning using the same heat exchanger  (Read 20472 times)
peacmar
Re: air conditioning using the same heat exchanger
« Reply #15 on: September 03, 2012, 03:24:48 PM »
Never ever thought this discussion would end up on this forum.... Wow. I've tried this also, works great! Sort of..... I too had problems with humidity. Cooled well but still sticky. There are so many different factors to cooling its rediculous. I do my own manual j inspection every time we remodel another room (100+ year old farm house) and heating is easy, but cooling is far from. Btus, tons, latent and sensible heat, blah blah blah....
I did learn one useful piece of knowledge though, that every 1 ton of cooling requires a 600 foot slinky coil stretched out I. A trench about 60 feet long if you are going to have a continuously cooling water supply. Otherwise you heat the ground and it takes a long time for dirt to dissipate heat. If you really want to dive in to an amazingly rewarding project, Google "diy heat pump" I've torn into a few window AC units now and use r-290 (propane) as the refrigerant. It's user friendly, legal, and safe with common sense. The entropy cycle is very interesting to study for the technical minded or the extreme diy'er.
I might add, that in order to remove humid you need to be at a temperature lower than the dew point. And have a very efficient coil to cool large amounts of air very quickly, surface area is key. More fins the better. Don't forget you need to have somewhere for that moisture to drain to. A used A-frame coil from central cooling would be a good start.
HandyMark
« Reply #16 on: September 03, 2012, 05:59:25 PM »
When I purchased my exchanger I bought a chilled water coil which is about 20x20 and five or six rows deep. Is it possible to pull enough moisture from the air using just ground temps if there is enough ground loop and enough surface area on the coil? I quick google search looks like dew point varies so I have not figured it all out yet.
PatrickfromPA
« Reply #17 on: October 22, 2012, 05:58:59 PM »
I have an inline water temp gauge from home depot water entering was 90 degrees-ish high 80's
OWB-wood doctor XL champion series
installed 1-16-2010
uses for my OWB-
heat house/garage- Air condition house/garage-
working on using the seebeck/thompson effect to generate electricity
